Help me pick a cpu Please
2 hours ago, AgentOfTheGame said:to start i want to say i only had intel cpus but im not a fan boy i okay going with AMD
i only game the res i play on is 1440p gpu is a 2080s or 2080 ti right now the i7-9700k is $300 usd and the i9-9900k is $450 usd and the 3700x is $330 usd those are the 3 cpus im looking at right now i have never really oc idk if i will trying to future proof my pc for streaming i dont know if i will i play games like Borderlands Destiny GTA 5 apex Hitman 2 Gears games like that for the cooler i already own a good one and its new and for ram i own 16gb 3000 ram if i need to change it i can. thanks for any help
Well you are in luck because both Intel and AMD make great CPU's in this generation
Which 1440p resolution are we talking - 2560 x 1440 (16:9 - Standard) or 3440 x 1440 (21:9 - Ultrawide)?
Which GPU is it, the 2080 Super or the 2080Ti as there is a fair bit of difference between the two, to check you can look on the card itself, you could also right click on your desktop and open the nVidia Control Panel then click system information in the bottom left to get the GPU info finally you could open your wallet, if there's money left you bought the 2080 Super, if its just lint and moths you got the 2080 Ti (there are other ways to check but these are quick/easy enough).
If your build is mainly gaming focused, then the i9 9900k is still top-dog for this single use, when it comes to gaming and streaming from the same rig you might find that the 9900k is no longer king and the crown goes to the 3900x (or soon to be released 3950x). So going on your needs and pure performance figures the 9900k is most likely the "best" CPU for your needs (the 3700k is a great CPU though and not a terrible purchase beating/matching the 9900k in a lot of areas outside of gaming). Unfortunately, the 1151 socket which the 9900k utilises is approaching end-of-life with Comet Lake (10th Gen) due to drop some time in the next 6 months, this will use a newer 1200 socket meaning that if you wanted to upgrade at a later date you will already have the best CPU available for your Motherboard meaning a larger upgrade would be required.
You say you already own a cooler, out of curiosity how old is it? if its an AIO and beyond 5 years I'd still consider replacing it (do you have the correct adaptors/mountings to make it fit the CPU's you've listed?)?
If you go the AMD route I would advise a RAM upgrade, 3600 CL16 seems to be the sweet spot and a lot of new kits like the G.Skill Trident Neo or Corsair Vengeance RGB Pro are "Ryzen Certified" so are better set out-of-the-box to pair with a Ryzen MOD and CPU.
Good luck in picking your new components
