144Hz Monitor on gtx 1660 ti
Go to solution Solved by arx,
6 hours ago, Dimitrispaok88 said:
60fps is problem with 144Hz monitor?
60 fps on a 144hz will feel horrible, if you are playing games like csgo, siege, mmos, overwatch etc... then you will be fine with your specs in terms of fluidity but if you're playing more intensive games on ultra you will feel the framerate tank and it will not be as smooth as playing games around the same frame rate as your refresh rate however its still playable just noticeably more choppier if you're playing on a 144hz monitor around 60-80 fps mark.
Hello. can i buy a monitor with 144Hz panel on my pc without problems?
My pc : Intel core i5 9400F
            GTX 1660 Ti
            16GB ram 3000Mhz
If you have the mood please tell me details about it and if there is a problem.
how many FPS and more. Thanks.
https://linustechtips.com/topic/1101642-144hz-monitor-on-gtx-1660-ti/
your FPS would depend on the games you play, if its esports titles for the most part, like siege, csgo, or rocket league, you should be able to fully utilize the 144hz of the monitor, but for open world games or some BR games you most likely wont make it far over 100 fps unless you seriously lower the graphics, but compatibility wise it will work without a problem, just make sure when you get it that you change the refresh rate in the nvidia inspector or whatever its called to 144hz. Also i would steer clear of 1440p panels with what you have now, as your graphics card is best suited for 1080p
I ran Destiny 2 with a 4.4Ghz 5820K (games the same as my i5 8400 did and that's basically the same CPU as the 9400F) and 1660 Ti at 1080p on my 144Hz panel, pushed 120-130fps or so which is what I normally get at that res with most CPUs (I had an OCed 8600K for a bit, that slapped it straight to 144fps with a 1080). 1660 Ti will do fine in most games for high refresh rates at 1080p, harder to run games are often open world or RPG style games that don't need high fps to be competitive like FPS titles do.
Main PC
CPU: i5 12600KF
Cooler: Noctua NH-L12S
Motherboard: ASRock Z690 ITX/ax
RAM: 2x16GB 3600Mhz DDR4
GPU: Intel ARC A770 16GB LE
Storage: 1TB MP34 + 2TB P41 + 2x 1TB MX500
ODD: LG WH14NS40
PSU: EVGA 850W GM
Case: Silverstone Sugo 14
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 15" M3 MacBook Air (work) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, flash, running Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2022 Kawasaki KLR650
no its not a problem, its just that its not really worth it to get a 144hz monitor if your framerate cant reach it, so if you want the best bang for your buck, you get a monitor with a refresh rate close to what your PC's framerate is
I'm running a 144Hz monitor with a 1050ti. Whether a 1660ti will suffice for your needs completely depends on what games you intend on playing.
For most titles, the 1660ti will pair well with a 144Hz display.
"Make sense? Oh, what fun is there in making sense?"
-Discord
