hi guys,
i'm looking to get into a new build and was either looking to purchase a new build or build my own.
was looking for some info on hardware and maybe some guidance into building the sickest rgb build ever
please drop some stuff down!
thank you
https://linustechtips.com/topic/1100018-rgb-build/
On 8/31/2019 at 2:03 PM, mattoasted said:
hi guys,
thank you
well my imo an internal usb rgb controller is way better then the build in rgb software that comes with some mb. i have corsair but othere are thermaltake, nzxt, aquacomputer, (ied stay away from coolermaster there stuff is garbage) if you have infant amount of money then ied say corsair or thermaltake or aquacomputer. i would pic parts that are addressable rgb 5v argb (means each led can have a different color in sted of the stranded rgb were all the leds are the same color) dint say anything about water cooling so i don't no. ek has good quality stuff so dose aqua computer for the most part.
https://linustechtips.com/topic/1100018-rgb-build/#findComment-12859195
