Windows Taskmanager (and Speedtest.net for that matter) report speeds in Mb, which stands for Megabit. Steam reports speeds in MB, which stands for Megabyte.
1 byte consists of 8 bits, so 1MB = 8Mb, or in your case it's 1.somethingMB = 9Mb.
The speeds you're getting between the test and download line up, it's just a different way of representing the numbers.
The numbers you're seeing are correct likely, because of that capitalized or small 'b'-letter
https://linustechtips.com/topic/1098099-please-help/#findComment-12841009
20 minutes ago, Zmax said:
What is your connection suppose to be. What you pay for.
Did you do a speed test. If not you should do the test , only to see if it's your system or your ISP.
I have a 50Mb and Steam is very slow even with a good connection
yeah sometime steam like cutting off the speed tho tbh. i mean most of launcher like that probably. like my shit origin.
  Spec: Macbook Air 2017
ProcessorPU: ii5 (I5-5350U |
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
 | GPU: Intel HD 6000 |
| Audio: JBL 450BT Wireless Headset |
https://linustechtips.com/topic/1098099-please-help/#findComment-12841026
