Help me choose the best system
first let's talk about the AMP thing
AMP : more power draw, more performance
so i suggest pick the Ryzen 5 2600 1660Ti non AMP
because 1660Ti will do high refresh rate 1080p and 1440p 60hz + and currently the best bang card for the category, also the AMP wont bring you much performance lift
also the ryzen platform will help you out when upgrading the CPU as it only requires cpu swap and bios update
Featured Topics
AlyShazli ·
4
Emmanuel Katto ·
Posted in Peripherals3 -
1
2
Rusty Proto ·
4
WildOne ·
Posted in New Builds and Planning1 -
solarbear ·
Posted in Troubleshooting1 -
5
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
