Help wit pcu connectors.
Solved by Kisai,
You have an HP, so that might be a specific HP PSU. If that's the case, the PSU is the 6-pin that you see the yellow and purple connectors near the top.
You can buy adapters for ATX to HP, but honestly that's a bit of a kludge and I'd probably suggest something like this:
https://www.newegg.ca/p/2S7-01JK-03R13?item=9SIAJ6A9179630
Double check what you actually have though, as though this is doable, it's likely that the chassis will not fit a non-HP PSU correctly since the PSU will likely be a different physical size with fan positions in not-deal positions.
