my cpu is a core i5 7400
cooler is cooler master gemini ii rgb
on windows doing nothing i get 50 c
on 50 percent usage i get 70 and on 100 usage i get up to 87
is it ok?
i changed from intel stock to this cooler four months ago maybe i did too much thermal paste or sth and also the fan is like a bit loose cause its soo big and i couldnt get the last screw to go in
https://linustechtips.com/topic/1094139-temps-are-hgh/
take off the cooler, clean off the cpu and cooler compltley, clean the fan out from dust, Install the cooler correctly with it making full contact with the cpu and you should be fine but otherwise no those temps are not normal
Current Rig=  AMD Ryzen 9 5900x, Asus Crosshair Hero VIII, EVGA RTX 3070 FTW3 ultra, 32gb Corsair Vengence Pro RGB 3000hz White, EVGA 750 P2 PSU, 1TB Samsung 980 Pro, 500gb samsung 860 evo, 250GB Samsung 850 evo, 2TB Samsung 970 Evo Plus, 2TB seagate firecuda sshd,  LianLi PC 011 Dynamic XL ROG edition, Corsair h150i elite capelix
https://linustechtips.com/topic/1094139-temps-are-hgh/#findComment-12808660
The Gemini is not so big a cooler, I'm not surprised. Still, those are perfectly safe operating temps
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1094139-temps-are-hgh/#findComment-12808741
It's still much better than the stock cooler which can easily keep temps in check for the 7400.
If by fan, you mean the cooler itself, then the cooler isn't properly installed. Reseat the cooler and make sure that it's evenly and gradually tightened in an X-pattern as opposed to one side before the other.
https://linustechtips.com/topic/1094139-temps-are-hgh/#findComment-12808944
On a high side, those. What motherboard you have? You can easily lower temps by setting up manual voltage. I can almost bet that's one reason load temps are so high.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1094139-temps-are-hgh/#findComment-12809471
