cooler sugestion for i5 9600k
imajerec
not intending to overclock it,at least untill i get a z board
case floston pure style
Do you already have it? because the R5 3600 not only is cheaper it actually is a superior CPU.
That said, can you specify your country and budget?
Personal Desktop":
Luna, the temporary Desktop:
yes i already have it, i bought it from someone for 115 euros which i considered a good deal,already instaled it but it gets hot with my 92mm deepcool(it costed 3 euro lol) which is basically a stock cooler it reaches  45-50c idle 70-80 C in games,it's also hot where i live
i was considering ryzen 3600,but the lowest price here is 205euro,and i already had a gigabyte b360m aorus gaming 3 board with an i3 8100,which the deepcool cheap cooler i had was enogh for cooling
you can make a sugestion from here
https://www.forit.ro/coolere/
cheapeast that will not make it reach past 65 C in load
4 hours ago, Epimetheus said:
Maybe the Hyper 212 Evo? I think there's a tier list on this forum somewhere
read about hyper 212 and so many people recommend it. personally i was looking at silentiumpc fera 3 and gammax 400
Unless the spec for the cpu height limit of 145mm I'm looking at is wrong, none of those coolers fit. Seems about right from the looks of the case though.
65c is unnecessarily low and a bit unrealistic without undervolting.
What ram and cooler do you currently have? It may be worth using the same cooler until you can get a better case that supports larger coolers.
Otherwise, the best cooler you can probably fit in the case is a NH-U9S: https://www.forit.ro/coolere/noctua/107413-nh-u9s/
the Frostwin LED may be better if it's as good as the Frostwin V2 but I haven't found much data on the cooler: https://www.forit.ro/coolere/deepcool/223293-frostwin-led/
2x8 ddr4 3200mhz adata gammix d30
i'm not spending that amount on 90mm coolers... i rather buy a new case first
and no OC btw, why is 65C unrealistic? :)
On 8/14/2019 at 9:11 AM, WoodenMarker said:
so i got a fera 3 cooler . it fit in my current case just fine. but feel like i didn't instal it right. i get around 40-45 C in idle and 60-65C in games which is ok i guess but those idle temps are kinda high
What are your ambient temps? Idle temps are generally limited to at least 10c higher than ambient.
A bad installation will generally show itself through load temps.
Amient temps arond 29-32C sometimes even hotter,it's pretty warm here now. I just spread the paste around the cpu die,instead of putting  just one point in the center and let the cooler spread it,thought that may affect it too? and the cooler stays at around 700rpm it doesn't go higher in normal tasks. in gaming it goes to 900, 1000rpm max
Spreading it shouldn't make much of a difference unless you're just removing too much paste from an area.
Your idle temps seem normal considering your high ambient temps.
