Corsair vs Winter and some other rambling
samuel
Sorry for bad image quality....
That was my PSU for like 3 months until it died unexpectedly. Bought it from a friend wich did not need a 500w PSU. Anyway, I'm not a Corsair hater, is just that my cheapo semi modular Super Flower rocks right now.
About the winter stuff... My CPU cooler is nothing special, it has a 80mm fan on a not so dense heatsync, but it does the job better than the stock cooler with very very low noise (due to my 120mm Coolink PWM fan attatched with custom (hand)made copper wires to the heatsync). But Piledriver it's hot, so I cannot just overclock my CPU further without toasting it. Util this morning: did some cleaning in my house, and left all the dors opened to get some fresh air. Also opened my PC to play some songs while doing the work. BOOM: 0 degreeds celius on the VRM, 2 degreeds celsius CPU temp itself. OKay, restarted HWinfo to make sure it's not a software bug. Nope, it was not. Immediatly after, an evil smile was showing up on my face. I HAD to do some sub-zero Overclocking. FX8320@5 GHZ 1.5v 15 min OCCT and I stopped, it was too cold for my skin.
Sadly, I forgot to do some screenshots, just now I had the idea to start this post. Hopefully it was not a bad one.
Verdict: don't buy Corsair CX and you can overclock like the big boys without expensive nitrogen or monster coolers.
FX8320 4.2Ghz@1.280v& 4.5 Ghz Turbo@1.312v Thermalright HR-02/w TY-147 140MM+Arctic Cooling 120MMVRM cooled by AMD Stock Cooler Fan 70MM 0-7200 RPM PWM controlled via SpeedfanGigabyte GA990XA-UD3Gigabyte HD 7970 SOC@R9 280X120GiBee Kingston HyperX 3K2TB Toshiba DT01ACA2001TB WD GreenZalman Z11+Enermax 140MM TB Apollish RED+2X Deepcool 120MM and stock fans running @5VSingle Channel Patriot 8GB (1333MHZ)+Dual Channel 4GB&2GB Kingston NANO Gaming(1600MHZ CL9)=14GB 1,600 Jigahurtz 10-10-9-29 CR1@1.28VSirtec High Power 500WASUS Xonar DG, Logitech F510Sony MDR-XD200Edifier X220 + Edifier 3200A4Tech XL-747H 3600dpiA4Tech X7-200MPdecent membrane keyboardPhilips 236V3LSB 23" 1080p@71Hz .
Sorry for my English....
Super Flower FTW!
Uhh. What were your ambient temps?
NZXT Phantom|FX-8320 @4.4GHz|Gigabyte 970A-UD3P|240GB SSD|2x 500GB HDD|16GB RAM|2x AMD MSI R9 270|2x 1080p IPS|Win 10
Dell Precision M4500 - Dell Latitude E4310 - HTC One M8
$200 Volvo 245
I've built custom WC rig with dual GPU and CPU and overclocked the shit out it on a CX750M, and a 4770k / 780 on a CX 500M
Tough shit about your PSU but it happens, nothing wrong with CX series for the price.
Outside were about -14 degreeds.... inside almost the same. The PC is located near the door.
I'm skeptical that you actually had the temperatures that were shown. I've had my windows open in -40C weather and my 4770k never got that low even on a stock clock.
Pew Pew Helicopters
my crappy thermaltek psu handles very well so far nothing died because of psu related issues ,i decided to increase the overclock a bit on my mining rig and let the window open when it was bit cold
http://i.imgur.com/8MqXkEK.jpg
although i am suprised that you were able to push it to 5ghz with 500w psu
Check that on AMD. My other rig (Dual Core E5500 775 platform) cannot get below 34 degreeds on the cores. A software limit I supose.
my 4770k @ 4.8ghz got down below 18 degrees through a similar idea of opening doors and windows. under load didnt peak over 65 so i would say it can make a difference however no one wants to deal with that kind of cold just for a big oc.
It was low, but it certainly was in the 0-5 range. The only way I've ever achieved that is with LN2 - but I tend to ruin hardware that way, so I haven't done it in a while - hah.
Pew Pew Helicopters
yeah thats my issue :/ its fun here and there if you wanna show your friends up though. then again ive only ruined one cpu and motherboard with ln2 the rest survived though the cpu's didnt clock so well even at stock anymore :P lol
I ended up throwing out most of the parts after I screwed up the last time. I haven't been back to LN2 since - not because I'm scared or anything, but just because I'm too lazy to take the time to set it up and potentially ruin $600+ in components, hah.
Pew Pew Helicopters
hmm, i should oc my pentium to 6ghz. -20° Celsius and wind outside.
I don't always have time to study, but when I do, I don't.
I was pretty woried of condesation effect.....but you can try if you want.
Winter overclocking. Alltho, if only WC rads were outside... :o sub zero watercooling setup.
pretty cool but how about summer time?
Sorry dude but without screenshots, it never happened.
Looks like you will have to freeze your ass of again.  :P
Nothing to see here - move along.
Wait what ?, did you put your PC near anything below ambient temperature when it was already hot ?.
And you wonder why your PSU broke?, I wonder why not more parts broke.
Unless you watercool it with vodka i do not recommend it.
since water freezes below zero and to counter if you put anti freeze in it your waterblocks and rads will die.
That PSU broke in the last spring in normal 18-25 degreeds ambient temps. It was startin for like 1 sec and power off by itself. A very common problem for CX 400/430/500... Don't have that link anymore to prove that. My current PC is located near the door in my room after wich you can find the holl, Yes, it was running at sub zero temps but not like -20 (when a hdd could start to have some issues.). It's not like my pc is running watercooling and the liquid inside froze or something like that. All modern PC parts are designed to withstand less then -10 degreeds but at a certain air moisture of wich I'm pretty damn sure it was a dry russian like clear sky freeze outside.
Thats how russians cool their computers down ahahaa
