So i have a h115i front mounted in a meshify C (can't mount it on top, top get this out of the way). Ever since installing the rad up front my gpu temps have increased quite a lot (up to 90°c under full load, cpu is at 45-50°). I have a G1 gigabyte 1080. I'm thinking of switching all my fans around so i'll have 1x140mm on top and 1x120mm in the back as intake and the 2x140mm on the aio in the front as exhaust. Would this be beneficial at all? Before i go and switch all the fans i wanted clarification / advice so that i don't do it for nothing. Has anyone done this? Thanks for the help!
https://linustechtips.com/topic/1090989-airflow-question/
You're just reversing airflow, air doesn't care.  You'll have cooler GPU temps and warmer CPU temps.
Try it and update this thread with the new temps, so we have some data to chew on.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1090989-airflow-question/#findComment-12783951
Doing it is the best way to figure it out!
My theory would be no it would not help, simply because the GPU's fans would be facing down, with the back plate facing the fans at the top. Basically you'd just be cooling the back plate of your card. The only way to know for sure though is experiment! Do it for science!!!
https://linustechtips.com/topic/1090989-airflow-question/#findComment-12784029
11 hours ago, Otto_iii said:
I think doing the experiment is best idea but assuming CPU isn't getting hot atm it should be a good trade-off, you never stated relative temps for CPU but id assume 65C or so?  Have you done anything with fan speeds at all?
CPU is at 75° max under aida 64 gpu + cpu stress test while the gpu is in the mid 80s. I have a quiet fan curve set for both but with my previous cooler which was a tiny air cooler my gpu didn't reach more than 75°c in any game with an even quieter fan profile. In gaming the gpu now sits at 75-80 at 2000mhz @ 1.0V, which is still okay but it would be great if it was even lower and the cpu is at 50 to 55 MAX while gaming at 4.3 @1.3V. I've bound my exhaust fans to the gpu temps now since i have a feeling that all the hot air is stuck in the case cause the cpu isn't getting hot during gaming. I will report the results and if i decided to switch out the orientation in the case after all!
https://linustechtips.com/topic/1090989-airflow-question/#findComment-12786702
So it would appear that the exhaust fans were indeed spinning too slow. I've set a curve so they spin via the gpu temps not cpu and i've brought down temps to mid to high 70s which is acceptable for now. I will try to reverse the fans to see if that helps ... in the future ... when i decide not to be so lazy :D
https://linustechtips.com/topic/1090989-airflow-question/#findComment-12787004
