Hello I have a Asus Prime Z390-a motherboard for the *th and 9th gen. Looking for a m2 ssd. I would like a 2tb ssd, but don't know the difference from some of these, for example I found one from 2TB WD Blue style m.2 2280 for $219.99, also found Intel 660p for $181.99. I just need it for games can Anyone give me some advice on what route I should go of if any of these two are good choice. those seem to be the cheapest.
https://linustechtips.com/topic/1090750-help-with-ssd/
Id personally get a 660p for games. Its about as cheap as you can get, and still plenty fast for load times.
Only big downside is the qlc flash, making the endurance lower(but your probably not installing more than one big game a day), and slow continous write speeds, but normally your network limited anyways, and not installing games that often.
https://linustechtips.com/topic/1090750-help-with-ssd/#findComment-12781846
Definitely go with the 660p over the WD Blue. The 660p is just about the slowest nvme drive you can get, but it's going to be MUCH faster than any sata drive.
If you can squeeze it, the Silicon Power P34A80 is at least twice as fast, and is only about $60 (Canadian) more than the 660p.
However, if fairly fast $/GB is all you care about, 660p is still the way to go.
https://linustechtips.com/topic/1090750-help-with-ssd/#findComment-12788422
660p looks to be the same as or slightly worse than the non-NVMe Blue: https://www.anandtech.com/show/14223/the-western-digital-wd-blue-sn500-ssd-review/3 (article is for the WD Blue SN500 NVMe drive, but has the normal Blue and a 660p on the charts as well)
If the 660p is cheaper for the same capacity it's better though.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/1090750-help-with-ssd/#findComment-12788435
I don't know that I agree with that reading of the article, for this given workload.
For gaming, read performance is what you most care about. And in both random and sequential read performance, the 660p is equal to or double the performance of the WD sata drive.
https://linustechtips.com/topic/1090750-help-with-ssd/#findComment-12788453
Even in tasks that don't take advantage of NVMe? IIRC NVMe only has an advantage in larger file transfers, games use a lot of tiny files.
Mouse: EVGA X17
https://linustechtips.com/topic/1090750-help-with-ssd/#findComment-12788455
No, NVME has an advantage with smaller files / random too.
AHCI is limited to one command cue, and 32 commands per cue. NVME has 65,535 command cues with 65,535 commands per cue (https://www.techrepublic.com/article/nvme-a-cheat-sheet/). That's a theoretical limit of about 4.3 billion commands in the same cycle that a sata drive could only do 32 (controllers are nowhere near maxing this out yet). And nvme also has a protocol for interrupting existing commands, where ACHI has to finish it's cue only one interrupt.
https://linustechtips.com/topic/1090750-help-with-ssd/#findComment-12788471
I have two of the 660p drives and they are garbage.  Will have a short burst of NVMe like speed and then drop to 1/2 of a decent SATA HDD.  The Samsung 970 Evo drives have been on sale lately.  Picked up a 1TB one for $169USD today.  For a few games a year, spend the money on something that will perform better and probably last longer.  Even the 500GB version would server you well.
https://smile.amazon.com/gp/product/B07BN217QG/ref=ppx_yo_dt_b_asin_title_o01_s01?ie=UTF8&psc=1
Gaming - AMD TR 3970X | ASUS ROG Zenith Extreme II | G.SKILL Neo 3600 64GB | Zotac Nvidia 2080 Ti AMP | 2x Sabarent 1TB NVMe | Samsung 860 EVO 1TB SSD | Phanteks Enthoo 719 | Seasonic Prime Ultra Platinum 1000w | Corsair K70 RGB Lux | Corsiar M65 | 2x ASUS Rog PG279Q | BenQ EW3270U | Windows 10 Pro | EKWB Custom loop
ITX - Intel i7-10700k | Asus ROG Z490-I Gaming | G.SKILL TridentZ RGB 3200 32GB | EVGA 2080 Super| Samsung 970 Evo 1TB | Samsung 860 Evo 1TB SSD | NZXT H1| Windows 10 Pro
HTPC - Intel i9-9900k | Asus ROG Maximus XI Code | G.SKILL TridentZ RGB 3200 32GB | EVGA 1070 | Samsung 970 1TB | WD Blue 1TB SSD | NZXT H700  | EVGA G3 1000W | Corsair H150i | Windows 10 Pro
Servers - SuperMicro 846 | 2x 2695L V2 | 128GB | Chelsio 10Gbe | Chelsio 40Gbe | 24 x 6TB | FreeNas - SuperMicro 826 | 2 x 2695L | 128GB | Chelsio 10Gbe | Chelsio 40Gbe | 8 x 10TB | 847 24 x 1TB SSD | Windows Server 2019
Work - Dell XPS 15 9560 | i7-7700HQ | 32 GB RAM | 1TB NVMe | 4k dsiplay
https://linustechtips.com/topic/1090750-help-with-ssd/#findComment-12788593
