One thing I enjoy doing often in writing is tabbing in, but this doesn't seem to work on the forums here, it just doesn't do anything. I'm assuming this is a known bug? I'm on Windows 10, on the latest build of Chrome.
Brands I wholeheartedly reccomend (though do have flawed products): Apple, Razer, Corsair, Asus, Gigabyte, bequiet!, Noctua, Fractal, GSkill (RAM only)
Wall Of Fame (Informative people/People I like): @Glenwing @DrMacintosh @Schnoz @TempestCatto @LogicalDrm @Dan Castellaneta
Useful threads:
How To Make Your Own Cloud Storage
Guide to Display Cables/Adapters
PSU Tier List (Latest)-
Main PC: See spoiler tag
Laptop: 2020 iPad Pro 12.9" with Magic Keyboard
PCPartPicker Part List: https://pcpartpicker.com/list/gKh8zN
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core OEM/Tray Processor  (Purchased For $419.99)
Motherboard: Asus ROG Crosshair VIII Formula ATX AM4 Motherboard  (Purchased For $356.99)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3000 Memory  (Purchased For $130.00)
Storage: Kingston Predator 240 GB M.2-2280 NVME Solid State Drive  (Purchased For $40.00)
Storage: Crucial MX300 1.05 TB 2.5" Solid State Drive  (Purchased For $100.00)
Storage: Western Digital Red 8 TB 3.5" 5400RPM Internal Hard Drive  (Purchased For $180.00)
Video Card: Gigabyte GeForce RTX 2070 8 GB WINDFORCE Video Card  (Purchased For $370.00)
Case: Fractal Design Define R6 USB-C ATX Mid Tower Case  (Purchased For $100.00)
Power Supply: Corsair RMi 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For $120.00)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For $75.00)
Total: $1891.98
Generated by PCPartPicker 2020-04-02 19:59 EDT-0400
身のなわたしはる果てぞ  悲しわたしはかりけるわたしは
https://linustechtips.com/topic/1090420-tabbing-does-not-work/
2 hours ago, VegetableStu said:
are you referring to
  • this but without the bullet? o_o
Yeah, more or less.
Useful threads:
Total: $1891.98
https://linustechtips.com/topic/1090420-tabbing-does-not-work/#findComment-12780261
7 hours ago, LogicalDrm said:
Can you clarify? Like do you mean indentation? For reading it's better that you leave empty row between paragraphs instead.
Here's an example ?
Useful threads:
Total: $1891.98
https://linustechtips.com/topic/1090420-tabbing-does-not-work/#findComment-12780275
4 minutes ago, VegetableStu said:
on a separate note: oh dang the ability to add <hr/> was removed o_o
What did that do?
Useful threads:
Total: $1891.98
https://linustechtips.com/topic/1090420-tabbing-does-not-work/#findComment-12780306
Just now, VegetableStu said:
horizontal row o_o let me try again
<hr></hr>
nope o_o
rip
Useful threads:
Total: $1891.98
https://linustechtips.com/topic/1090420-tabbing-does-not-work/#findComment-12780329
45 minutes ago, SenKa said:
Here's an example ?
That kind of editing makes reading it on mobile or other smaller screens messy. Empty line brake between paragraphs is much clearer. And you can use centered text if you want to make a point or something.
26 minutes ago, VegetableStu said:
I was trying to see if HTML paragraph tags would work somehow with additional formatting or something, but I think direct HTML tags are completely disabled now ,_,
Are you mixing HTML to BBCode perhaps? I don't think HTML has ever been allowed due to all security issues it can bring. But some BBCode tags should still work, the basic ones at least.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1090420-tabbing-does-not-work/#findComment-12780435
EDIT: ugh why did this randomly post... :/ Where's the delete button lol
EDIT2: adding some spaces
        like this :D
does work! So you could do that instead. :) As to why tabbing/indenting doesn't work, no clue.
PC SPECS: CPU: Intel Core i7 3770k @4.4GHz - Mobo: Asrock Extreme 4 (Z77) - GPU: MSI GeForce GTX 680 Twin Frozr 2GB - RAM: Crucial Ballistix 2x4GB (8GB) 1600MHz CL8 + 1x8GB - Storage: SSD: Sandisk Extreme II 120GB. HDD: Seagate Barracuda 1TB - PSU: be quiet! Pure Power L8 630W semi modular  - Case: Corsair Obsidian 450D  - OS: Windows 7
https://linustechtips.com/topic/1090420-tabbing-does-not-work/#findComment-12780639
You can use bold/italics/quote tags/font size/colour/paragraph spacing to highlight the key points. You can use tab to additionally indent bullet points, but it is not something that I am planning to add for paragraph text.
HTTP/2 203
https://linustechtips.com/topic/1090420-tabbing-does-not-work/#findComment-12780650
        like this :D
You do realize that because this is responsive site, everything that looks "good" on your monitor, will look bad on mine?
https://linustechtips.com/topic/1090420-tabbing-does-not-work/#findComment-12781011
Yes. To test this, I narrowed down this Window as much as possible (to 480 pixels wide, I assume), and it still looks good, even in the quote.
(mini rant: I actually haven't used the LTT forum since we moved to a newer forum version in 2015. As it became unusable on mobile, my (by fair) main platform, I ended up leaving the forum. Only recently returned because I needed some help with somethnig. I still solely use it on desktop. Still sad lol)
Posting in this narrow mode is fun, by the way. :P
https://linustechtips.com/topic/1090420-tabbing-does-not-work/#findComment-12781038
