calling all skilled network pros... I need HELP!
mr moose
Now I have your attention, I would like someone to educate me on the possibilities of playing Hexen with a friend across the internet.
The game for those not familiar:  http://en.wikipedia.org/wiki/Hexen:_Beyond_Heretic
I believe the game uses  IPX protocols on local network to enable co operative multiplayer.  So what I ultimately want is a network setup across the internet (like vpn or something) that the game will see as a local network and allow IPX between myself and anyone other computer that joins the network.
Cheers for any help.
Grammar and spelling is not indicative of intelligence/knowledge.  Not having the same opinion does not always mean lack of understanding.
You had me at all caps.
But I'm sorry, I can't help you.
8320 @ 4.3ghz l Gigabyte 970a Ud3 l Hyper 212 Evo l R9 290 l 8gb RAM 1866 Vengeance l 1tb WD Black l 120gb Samsung Evo SSD l HX750 Gold PSU l 500d Arctic Case l Windows 8 OS l K65 and Blackwidow Keyboard l M65 and DeathAdder 2013 l Qck Steelseries l 24in Vizio Monitor 1080p
I'm no networking expert, but would something like Hamachi work? https://secure.logmein.com/products/hamachi/download.aspx
Thanks, That looks promising, do you/anyone know how secure it is?
I'm pretty sure you can add a password to prevent other people accessing your session, beyond that I have no idea, I've never had any worries about using it though.
You had me for a second, but then I read the actual question. You do not need a professional for that...
hamachi's decent, I mean you're playing games after all, not sending secret codes through some minute vibration of sounds that'll bring ww3 - right?
by the way can't help but to remember some young hobos back in seattle holding a sign saying BEER!!! then with little writing on the bottom
now that I got your attention, spare some change? hilarious :P
Check out the build: Used to be Obot, now Lilith
Shameless: Me
Um, yeah... that's rrright, I'm not doing that, I am playing games, yeah games that's it,  Minecraft and such. chope chope mine mine. :ph34r:
Cheers I will see if i can get this thing working tonight.
If i recall correctly, when you copy wsock32.dll into the root folder of the game it lets you use TCP/IP instead of IPX. Works for some games.
Something wrong with your connection ?
Run the damn cable :)
Any VPN service should work just fine. Used to play quake with friends using Hamachi.
AMD RYZEN 7 5800X3D \ Gigabyte X570 Aorus Elite \  32GB 3600 G.SKILL Neo \  Gigabyte RTX 4080 Gaming OC \  Lian Li O11 Dynamic Evo \  NVMe 2TB Samsung 990 Pro, SATA 4TB Samsung 970 Evo  \  WINDOWS 11 PRO
It never troubles the wolf how many the sheep may be. ~Publius Vergilius Maro circa 50BC
