Hello I am new to the pc building scene, and just completed my first ever build on my own here are the specs.
  Продукти
  GPU: ASUS PHOENIX GTX 1650 OC Edition 4GB GDDR5 128 bit
  Motherboard :ASUS TUF B450M-Pro Gaming socket AM4, 4xDDR4, Aura Sync
  CPU:AMD RYZEN 5 2600 6-Core 3.4 GHz (3.9 GHz Turbo) 19MB/65W/AM4/BOX
  RAM: Team Group Delta Blue DDR4 - 16GB (2x8GB) 3000MHz CL16-18-18-38 1.35v
  Power: Gigabyte G700 700W 80+ bronze Semi-Modular
  Case: Cooler Master MasterBox Lite 3.1 MCW-L3B3-KANN-01, mATX, Черен
  HDD WD Blue, 1TB, 7200rpm, 64MB, SATA 3
  SSD: SanDisk Plus, 2.5", 240GB, SATA3
  Mouse: SteelSeries, Rival 310 Black,
Keyboard: Steelseries Apex 150,
Monitor: Acer GN246 TL
It all ended up costing me a around 1050 euros
https://linustechtips.com/topic/1087869-rate-my-first-build/
How much did your GPU cost you? The 1650 has been notoriously overtired since launch, the RX 570 from AMD creams it for a ton cheaper usually.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1087869-rate-my-first-build/#findComment-12759167
Give us actual inside shots of the build so we can critique that.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1087869-rate-my-first-build/#findComment-12759180
13 minutes ago, spre4 said:
It was around 150 euro, it was like 55 euro cheaper than the rx 570 here in Bulgaria
If it was that much cheaper then it did make sense to buy
Primary PC:
PSU tier list
https://linustechtips.com/topic/1087869-rate-my-first-build/#findComment-12759191
2 minutes ago, spre4 said:
Yeah it was some kinda of a promotion here in Bulgaria, and what do you think for the rest of it?
Can't really judge it based in cost, the TUF motherboard is also usually overpriced but is fine if gotten cheap, and I don't really know anything about that PSU either (except that 700 watts is way more than any gaming rig needs)
Primary PC:
PSU tier list
https://linustechtips.com/topic/1087869-rate-my-first-build/#findComment-12759213
Airflow of this case is bad from my memory
One of the slowest SATA SSD, it'd better be cheap
Monitor doesnt have 144Hz capability with anything but DVI port, limiting future graphics card choice
what about the 1060? Even 3gb model is faster
Desktop benching:
https://linustechtips.com/topic/1087869-rate-my-first-build/#findComment-12759219
Um.......
For 800€ + monitor you should in most locations get something like a 2600 + 5700
So unless your country has very odd pricing. Thats not a great deal.
PCPartPicker Part List
CPU: AMD Ryzen 5 2600 3.4 GHz 6-Core Processor  (€129.90 @ Alternate)
Motherboard: ASRock B450M Pro4-F Micro ATX AM4 Motherboard  (€78.84 @ Mindfactory)
Memory: Crucial Ballistix Sport LT 16 GB (2 x 8 GB) DDR4-3000 Memory  (€71.24 @ Amazon Deutschland)
Storage: Crucial MX500 500 GB 2.5" Solid State Drive  (€67.90 @ Amazon Deutschland)
Video Card: PowerColor Radeon RX 5700 8 GB Video Card  (€357.99 @ Mindfactory)
Case: Cooler Master MasterBox Q300L MicroATX Mini Tower Case  (€38.90 @ Caseking)
Power Supply: be quiet! Pure Power 11 CM 500 W 80+ Gold Certified Semi-modular ATX Power Supply  (€74.00 @ Amazon Deutschland)
Total: €818.77
Generated by PCPartPicker 2019-07-29 14:05 CEST+0200
German pricing and stretching a little.
This doesnt apply everywhere offcourse
https://linustechtips.com/topic/1087869-rate-my-first-build/#findComment-12759228
