HELP! i7-7700 Driver
What's happening is that because you are using a dedicated graphics card, the Gigabyte Motherboard by default, will turn off the on-board graphics. Windows can't see it so when you try to install the intel drivers, what the error message really means is, "you don't meet the minimum requirement because you don't even have this card." So, unless you plan on removing the graphics card and using just the onboard, you can just leave it be.
If you have need for the built-in graphics card for multi-monitor setups or am a completionist and it'll just bug you forever if you don't install the driver, then go into the UEFI, under the Chipsets settings there should be an "Internal Graphics." Change it from "auto" to "enabled" then the motherboard won't turn the intel onboard GPU off once it detects that your deidcated graphics card is plugged in, and you can go ahead and install that one, last, driver.
I have a Gigabyte Z-170x and took me a while to figure it out lol.
