Switching out fans on Noctua D15 D15S ?
jamsincali
Hey guys.
So with the Noctua D15 Series I know it comes with fans but clearance is a little tricky. My question is what will I see different when it comes to switching out the stock 140s for 120mm?
Here are the fan specs. LNA = Low Noise Adapter
Stock
2 NF-A15S 140MM
Speed 1500/1200LNA
CFM 82.51/67.98LNA
PRESSURE 2.08/1.51LNA
NOISE DB 24.6/19.2LNA
Possible Replacements
2 NF-F12 120MM
Speed 1500/1200LNA
CFM 54.97/43.78
PRESSURE 2.61/1.83LNA
NOISE DB 22.4/18.4
So if I just look at the numbers the 120mm is gonna be quiet at both normal and LNA settings. The 140mm will have  MUCH HIGHER CFM at normal and LNA setting. Lastly the 120mm has way more static pressure at full speed and a higher pressure rating at low noise setting.
This is going on a chip that has a TDP rating of 165W
Your help is greatly appreciated
J
If RAM clearance is an issue, you can always move the fan upwards a bit.  Not the prettiest of sights, but then again neither is a 120mm wide fan on a 150mm wide cooler.
True. But how would the NF-F12's perform compared to the stock ones?
  Reveal hidden contents
I think it will performs in between D15S & D15, since the D15S only use single 140mm, and D15 use a pair 140mm, while your plan will be 140+120mm.
The difference between D15 & D15S is only 1-3C, and it's negligible.
SILVER GLINT
CPU: AMD Ryzen 7 3700X || Motherboard: Gigabyte X570 I Aorus Pro WiFi || Memory: G.Skill Trident Z Neo 3600 MHz || GPU: Sapphire Radeon RX 5700 XT || Storage: Intel 660P Series || PSU: Corsair SF600 Platinum || Case: Phanteks Evolv Shift TG Modded || Cooling: EKWB ZMT Tubing, Velocity Strike RGB, Vector RX 5700 +XT Special Edition, EK-Quantum Kinetic FLT 120 DDC, and EK Fittings || Fans: Noctua NF-F12 (2x), NF-A14, NF-A12x15
The 2000rpm iPPC NF-F12's at 15v is probably pretty representative of the performance.
https://www.hwcooling.net/en/how-sensitive-is-ninja-5-to-airflow-changes/3/
https://www.hwcooling.net/en/test-scythe-ninja-5-evolution-of-the-revolutionary-predecessor/4/
So from hwcooling's example, going from 65c with stock fans to 68.5c with NF-F12's.
You're probably better off with a single NF-A15 at the middle which wouldn't get in the way of anything. What case and ram are you using?
thanks!
