I want to build a pc for my friend to play 1080p games at 60 fps for a good price but I'm not too sure where to start I found a dell OptiPlex that has a i7 3770 16 gb of ddr 3 ram 500gb HDD 120gb ssd and a AMD Radeon 7570. my plan is to switch the graphics card  with a gtx 1660 and call it a day but I'm not sure how it would perform and if it would be good enough my max budget is 750
https://linustechtips.com/topic/1086580-a-pc-for-a-friend-help/
For $750 in the U.S. we can put together a solid system that will outdo the old 3770.
Here's an idea:
https://linustechtips.com/topic/1086580-a-pc-for-a-friend-help/#findComment-12750826
If we were talking about a custom built PC with a decent MOBO, PSU, and an unlocked 3770k, it might be worth reviving. A locked 3rd gen CPU with a proprietary MOBO, a generic PSU, and a junky old office PC case isn't, however. At least not if you've got more than $4-500 to play around with.
The build above would significantly destroy that.
https://linustechtips.com/topic/1086580-a-pc-for-a-friend-help/#findComment-12750828
1 minute ago, trevb0t said:
If we were talking about a custom built PC with a decent MOBO, PSU, and an unlocked 3770k, it might be worth reviving. But if you've got a $750 budget, the old Optiplex plus used GPU isn't the right fit. That's more for folks on a $300 budget.
yea ok the list is 981 cad that's a bit much maybe a different  cpu?
https://linustechtips.com/topic/1086580-a-pc-for-a-friend-help/#findComment-12750835
and no overclocking I want to give him a pc that he doesn't have to worry about so its stable by its self
https://linustechtips.com/topic/1086580-a-pc-for-a-friend-help/#findComment-12750838
6 minutes ago, trevb0t said:
I switched the asrock board for an asus one its like 5 bucks cheeper but I like the asus boards easy to work with and I havnt heard many good things from asrock  from a co worker
https://linustechtips.com/topic/1086580-a-pc-for-a-friend-help/#findComment-12750873
The Asus low end boards have pretty bad heat problems. It's low end. The ASRock Pro4 is where midrange starts. It's a step up for that $5 extra.
If we were talking about the $150 board range, I'd take ROG over ASRock all day.
If you step up a few bucks, the MSI B450M Bazooka board is very solid at the price point. It's over $100 in CAD though.
https://linustechtips.com/topic/1086580-a-pc-for-a-friend-help/#findComment-12750885
Thats bottom barrel B450 board, you might as well get the bottom barrel Asrock for $10 cheaper. Asrock (budget) and MSI (across the range) are the go-to currently for AMD boards.
PCPartPicker Part List
CPU: AMD Ryzen 5 1600 3.2 GHz 6-Core Processor  ($169.99 @ Amazon Canada)
Motherboard: MSI B450M BAZOOKA V2 Micro ATX AM4 Motherboard  ($109.50 @ Vuugo)
Memory: G.Skill Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 Memory  ($85.99 @ Newegg Canada)
Storage: TCSunBow X3 480 GB 2.5" Solid State Drive  ($57.99 @ Amazon Canada)
Video Card: Sapphire Radeon RX 580 8 GB PULSE Video Card  ($259.50 @ Vuugo)
Case: Thermaltake Versa H17 MicroATX Mini Tower Case  ($44.99 @ Amazon Canada)
Power Supply: Corsair CX (2017) 450 W 80+ Bronze Certified ATX Power Supply  ($64.75 @ Vuugo)
Total: $792.71
Generated by PCPartPicker 2019-07-26 02:48 EDT-0400
CPU: AMD Ryzen 5 3600  Heatsink: ID-Cooling Frostflow X GPU: Zotac GTX 1060 Mini 6GB RAM: KLEVV Bolt 3600Mhz (2x8GB) Mobo: ASUS B550-F ROG Strix (Wifi)  Case: Fractal Design Meshify C PSU: Deepcool DQ-M-V2L
https://linustechtips.com/topic/1086580-a-pc-for-a-friend-help/#findComment-12750891
There you go....
Motherboard: MSI B450M GAMING PLUS Micro ATX AM4 Motherboard  ($104.99 @ Newegg Canada)
Memory: Team Dark 16 GB (2 x 8 GB) DDR4-3000 Memory  ($82.99 @ Newegg Canada)
Video Card: XFX Radeon RX 580 8 GB GTS Black Core Edition Video Card  ($234.99 @ Newegg Canada)
Power Supply: Cooler Master MasterWatt 550 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($68.88 @ Canada Computers)
Total: $764.82
Generated by PCPartPicker 2019-07-26 02:58 EDT-0400
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1086580-a-pc-for-a-friend-help/#findComment-12750914
Oh ok good to know
https://linustechtips.com/topic/1086580-a-pc-for-a-friend-help/#findComment-12751070
