I was planning to buy an NZXT H500i but many people told me it didn’t have the best air flow .. then I was looking at the Corsair 460x but turns out it’s really hard to get good cable management on that case , any recommend cases that have good air flow but still look pretty decent ?
https://linustechtips.com/topic/1085822-cases-with-good-air-flow/
Phanteks Enthoo Pro M TG
I've heard good things about the Meshify C.
CPU: Ryzen 5 5600x  | GPU: GTX 1070 FE | RAM: TridentZ 16GB 3200MHz | Motherboard: Gigabyte B450 Aorus M | PSU: EVGA 650 B3 | STORAGE: Boot drive: Crucial MX500 1TB, Secondary drive: WD Blue 1TB hdd | CASE: Phanteks P350x | OS: Windows 10 | Monitor: Main: ASUS VP249QGR 144Hz, Secondary: Dell E2014h 1600x900
Meshify C is pretty hard to beat for airflow, I mean full mesh front and will take 2 140mm fans at the front. All for less than $90.
CPU: AMD Ryzen 5 3600  Heatsink: ID-Cooling Frostflow X GPU: Zotac GTX 1060 Mini 6GB RAM: KLEVV Bolt 3600Mhz (2x8GB) Mobo: ASUS B550-F ROG Strix (Wifi)  Case: Fractal Design Meshify C PSU: Deepcool DQ-M-V2L
5 minutes ago, xzplicit said:
Do you think the cool master H500 is a good case as wel?
Its fine, but it costs more than the Meshify C which I can kind of find hard to justify as it doesn't seem to do anything that the Meshify can't do.
