Hey Linus tech tips forums.
im soon going to be building my very first pc, its not only going to be the first pc i build its also going to be my very first gaming pc.
Im going to go for an AMD 8350 paired with a Noctua NH D-14 for overclocking. I was first going to go with the Gigabyte GA-970A-UD3P Mobo but somone told me that it had bad power something something. He recomended me some other board an Asus M5A99X Evo R2.0 but he dident really explain why its better, i know that it has a better overclocking chipset but AMD cpu´s should be pretty easy to overclock, can you guys help find a good mobo wile still explaining to me why its better. Thanks in advance :D
Edit: Budget for mobo is around 120 dollars, just take into consideration that im from europe and we have slightly higher prices
https://linustechtips.com/topic/108424-amd-8350-mobo-help/
budget?
Specs
https://linustechtips.com/topic/108424-amd-8350-mobo-help/#findComment-1449440
Specs
https://linustechtips.com/topic/108424-amd-8350-mobo-help/#findComment-1449496
990FXA-UD3. 8+2 phases. Latest revesion doesn't have AMD AMP swich so your CPU will throtle when stressed with intel burn test and prime95. In real world scenarios, the performance will be the same with or without AMP (cinebench for example)  Also your mobo NB hill get hot...but that's by design. A good cheap well featured board overall. But just don't go insane with the overclocks.
FX8320 4.2Ghz@1.280v& 4.5 Ghz Turbo@1.312v Thermalright HR-02/w TY-147 140MM+Arctic Cooling 120MMVRM cooled by AMD Stock Cooler Fan 70MM 0-7200 RPM PWM controlled via SpeedfanGigabyte GA990XA-UD3Gigabyte HD 7970 SOC@R9 280X120GiBee Kingston HyperX 3K2TB Toshiba DT01ACA2001TB WD GreenZalman Z11+Enermax 140MM TB Apollish RED+2X Deepcool 120MM and stock fans running @5VSingle Channel Patriot 8GB (1333MHZ)+Dual Channel 4GB&2GB Kingston NANO Gaming(1600MHZ CL9)=14GB 1,600 Jigahurtz 10-10-9-29 CR1@1.28VSirtec High Power 500WASUS Xonar DG, Logitech F510Sony MDR-XD200Edifier X220 + Edifier 3200A4Tech XL-747H 3600dpiA4Tech X7-200MPdecent membrane keyboardPhilips 236V3LSB 23" 1080p@71Hz .
Sorry for my English....
https://linustechtips.com/topic/108424-amd-8350-mobo-help/#findComment-1449497
Yes, avoid 970 boards for 83XX chips.
Oneplus 6 | Sony 55" X900F . Lenovo Y540 17" 144Hz RTX 2060 . i7 9750h.
Audio-GD DAC-19MK3 > Schiit Lyr 2 + > FOSTEX TH900 . Sony XBA-Z5
https://linustechtips.com/topic/108424-amd-8350-mobo-help/#findComment-1450904
I am currently in a similar situation, I have a fx 8320 running in a Asus M5A78L-M/USB3.
I really want to overclock the CPU and really like the Sabre-toothed but I also found this MSI board.  http://www.novatech.co.uk/products/components/motherboards/amdam3plus990fx990xchipset/atxformfactor/990fxa-gd65.html
MSI 990FXA-GD65 AMD 990FX (Socket AM3+) Motherboard
https://linustechtips.com/topic/108424-amd-8350-mobo-help/#findComment-1452376
All I can say is that I have the Gigabyte UD3 and am happy with it apart from it throttling when folding or running Boinc.
I am returning it to Overclockers UK (Who are brilliant) and getting the Sabertooth.  I know it will still have the same issues but a lot less.
Nothing to see here - move along.
https://linustechtips.com/topic/108424-amd-8350-mobo-help/#findComment-1456728
Gigabyte UD3 is your only option at $120. Keep an eye out for sales.
Air 540, MSI Z97 Gaming 7, 4770K, SLI EVGA 980Ti, 16GB Vengeance Pro 2133, HX1050, H105840 EVO 500, 850 Pro 512, WD Black 1TB, HyperX 3K 120, SMSNG u28e590d, K70 Blues, M65 RGB.          Son's PC: A10 7850k, MSI A88X gaming, MSI gaming R9 270X, Air 240, H55, 8GB Vengeance pro 2400, CX430, Asus VG278HE, K60 Reds, M65 RGB        Daughter's PC: i5-4430, MSI z87 gaming AC, GTX970 gaming 4G, pink air 240, fury 1866 8gb, CX600, SMSNG un55HU8550, CMstorm greens, Deathadder 2013
https://linustechtips.com/topic/108424-amd-8350-mobo-help/#findComment-1457130
