specs:
i7 8700K (non OC)
Corsair H115i Pro Platinum 280mm rad (top mounted)
MSI Z370 Tomahawk
4x 8GB Corsair Vengeance PRO 3200MHz
I regularly do video encoding which uses 100% of the CPU, no problem there.
Since the AIO, I am not hitting over 72 C while under full load on the chip but the VRM on the left gets frickin hot.
The one on the top gets airflow from AIO, it is hot to the touch but still aight. The one on the left, i can burn my finger on.
IS this okay, do i fix this ?
I am here to learn, please correct me if im wrong or you see me putting bs on your screen!
https://linustechtips.com/topic/1080373-very-hot-vrms/
How hot is hot?
They should be rated for 5000 hours at 105 degrees.
You can put a slow spinning fan above it if you like.
AMD 5900x, 2x16GB ( G.skill F4-3600C16 ), Radeon VII, Radeon 570,  Corsair 1200i , SSD 240/500GB, HDD 640GB,1TB,5TB, 1TB NVME. Lian li 011Dyanmic XL, big ass LTT mouse-pad & stealth water bottle
https://linustechtips.com/topic/1080373-very-hot-vrms/#findComment-12704545
Could you actively cool it with a small fan perhaps? Like the old northbridge fans that were popular some years ago?
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/1080373-very-hot-vrms/#findComment-12704561
On 7/9/2019 at 11:09 PM, TheTallGuy said:
How is the airflow situation in your case, which case do you have?
2x ML 140 on the front - intake
1x ML 140 on the back - out
2x ML 140 on the top - out - AIO
Also no side pannel on :D
https://linustechtips.com/topic/1080373-very-hot-vrms/#findComment-12727885
sometimes the side panel helps with airflow but like someone said , VRMs are designed to run hot. I built a mate a PC in a cheap case and there was a eddy current around the VRMs. They lived at 80-85C.
https://linustechtips.com/topic/1080373-very-hot-vrms/#findComment-12728180
On 7/9/2019 at 11:05 PM, Jesmo said:
What temps do you get in HWmonitor?
i ill check the temps when i get home. might idd just be like 80C.
https://linustechtips.com/topic/1080373-very-hot-vrms/#findComment-12728302
It is meant to get hot sorta like how M.2 SSD gets about twice as hot as SSD.  But I did research and they say its meant to get really hot to work properly and what not.  If things are nice and hot then something is wrong / your PC isn't turning on LOL
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1080373-very-hot-vrms/#findComment-12728537
If really concerned get an L shape piece of metal (or 2 if you use same size fan as your exhaust fan since you have an AIO and a CPU cooler wont be in the way) drill hole in each end of the L shape and affix it to the inner screw(s) into the rear exhaust fan creating a second bracket to mount a fan on to actively cool your VRMs.  I.E. you can go 40/80mm, use 1 L shape bracket and never worry about it again.  If you do it right it wont look bad at all either.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/1080373-very-hot-vrms/#findComment-12728549
I just want someone to buy that Cryorig A80 and report back if it actually works
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
https://linustechtips.com/topic/1080373-very-hot-vrms/#findComment-12728560
Didn't know this existed...DIY is so much cheaper (watching video on it now, neat idea however)
https://linustechtips.com/topic/1080373-very-hot-vrms/#findComment-12728582
i'm just surprised its taken so long for a manufacturer to think of this
https://linustechtips.com/topic/1080373-very-hot-vrms/#findComment-12728675
I ve seen this before somewhere. from a different brand, but it hurts the estheatics a bit. They wanna make big profits ofc
https://linustechtips.com/topic/1080373-very-hot-vrms/#findComment-12729431
