My graphics card (rx580) runs very hot, and I just found out that all of the exhaust from the fans blows directly into the side panel which increases the temp really fast. I don’t want to keep the panel off but it drops my temps by 20C instantly when I remove it.
https://linustechtips.com/topic/1080305-problem-with-temps-and-side-panel/
If you have an open cooler card, that's just the nature of they work. The only way to keep their temps down outside of removing the side panel is to make sure it has plenty of breathing room below it and there's steady airflow.
