Thinking of my first AIO for a 6700k.
Solved by WoodenMarker,
19 minutes ago, Kierax said:Would an AIO then be wise with the front intake being what it is on an NZXT 340? presuming I could increase the budget what would be recommended as decent?
An air cooler would be quieter and / or cheaper.
If you just want something better, the Gammaxx 400 is alright:
The SR Slim would be better if you want something very quiet: https://uk.pcpartpicker.com/product/Zr2kcf/be-quiet-cpu-cooler-bk010
If you want rgb, the Hyper 212 RGB BE performs a bit better but isn't as quiet: https://uk.pcpartpicker.com/product/hHDJ7P/cooler-master-hyper-212-rgb-black-edition-573-cfm-cpu-cooler-rr-212s-20pc-r1
