Ahh, Overwatch. The game engine is so damned buggy for a stable release game...
Turn off vSync, run in Borderless Windowed. Uncap FPS, max settings. Disable any antivirus and RGB software. May I ask what software you're using to display system stats? It looks really nice.
Also, why is your OS installed on a 2TB HDD and not your 860 Evo? Also, you need to look in to tightening up those RAM timings. That is some of the worst DDR4 I have seen
Brands I wholeheartedly reccomend (though do have flawed products): Apple, Razer, Corsair, Asus, Gigabyte, bequiet!, Noctua, Fractal, GSkill (RAM only)
Wall Of Fame (Informative people/People I like): @Glenwing @DrMacintosh @Schnoz @TempestCatto @LogicalDrm @Dan Castellaneta
Useful threads:
How To Make Your Own Cloud Storage
Guide to Display Cables/Adapters
PSU Tier List (Latest)-
Main PC: See spoiler tag
Laptop: 2020 iPad Pro 12.9" with Magic Keyboard
PCPartPicker Part List: https://pcpartpicker.com/list/gKh8zN
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core OEM/Tray Processor  (Purchased For $419.99)
Motherboard: Asus ROG Crosshair VIII Formula ATX AM4 Motherboard  (Purchased For $356.99)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3000 Memory  (Purchased For $130.00)
Storage: Kingston Predator 240 GB M.2-2280 NVME Solid State Drive  (Purchased For $40.00)
Storage: Crucial MX300 1.05 TB 2.5" Solid State Drive  (Purchased For $100.00)
Storage: Western Digital Red 8 TB 3.5" 5400RPM Internal Hard Drive  (Purchased For $180.00)
Video Card: Gigabyte GeForce RTX 2070 8 GB WINDFORCE Video Card  (Purchased For $370.00)
Case: Fractal Design Define R6 USB-C ATX Mid Tower Case  (Purchased For $100.00)
Power Supply: Corsair RMi 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For $120.00)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For $75.00)
Total: $1891.98
Generated by PCPartPicker 2020-04-02 19:59 EDT-0400
身のなわたしはる果てぞ  悲しわたしはかりけるわたしは
https://linustechtips.com/topic/1078774-help-with-overwatch/#findComment-12692945
9 hours ago, Gilbert.b said:
I have gone done to the lowest setting and that didn't work
What software are you using for those? Does built-in give same numbers? Does gameplay feel like it's at 30fps?
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1078774-help-with-overwatch/#findComment-12696139
There has to be something else badly wrong with your system. Like, mistakenly capping the framerate to some value or something. There is no way 8700K and RTX 2070 should be getting 30-ish framerate when I get like gazillion FPS maxed out on GTX 1080Ti and 5820K which is a lot slower CPU.
https://linustechtips.com/topic/1078774-help-with-overwatch/#findComment-12696532
12 minutes ago, Gilbert.b said:
built-in gives the same num
Uhh... Have you done drivers already? Answering only one of the questions at the time will take us forever to solve this
https://linustechtips.com/topic/1078774-help-with-overwatch/#findComment-12696978
1 minute ago, Gilbert.b said:
sorry drivers are up to date the program is the NZXT CAM
Try with older drivers too. Sometimes newest can have issues with older games.
https://linustechtips.com/topic/1078774-help-with-overwatch/#findComment-12696999
