On 7/4/2019 at 7:43 AM, lavaslime44 said:
I'm looking for a case with a PSU basement, vertical GPU mounts, and EATX support any ideas would be greatly appreciated.
Are you watercooling or Air cooling the card?
What is your case budget?
Where are you located?
What is your system build (or planned)?
https://linustechtips.com/topic/1078622-case-help/#findComment-12694311
