I a planning to build a watercooled raspberry pi (not for performance, for fun). Here are the parts : Please let me know if there are any issues
Water block :  s-l1600.jpg
Pump :  s-l1600.jpg
Tubing : (what size should I get ?) s-l1600.jpg
Thermal adhesive Halnziye-HY910-5g-Silicone-Thermal-Glue-Adhesive-LED-GPU-VGA-RAM-VR-Heatsink
Radiator (coke bottle)Image result for coke 500ml
DIY radiator s-l1600.jpgs-l1600.jpg+Halnziye-HY910-5g-Silicone-Thermal-Glue-Adhesive-LED-GPU-VGA-RAM-VR-Heatsink
Test Victim subject : raspberry pi model 2
Edited by LogicalDrm
If you want me to see your reply, please tag me @Faisal A
Seems like a fun project! :D
If you want to, there are kits as well, to help you get an idea of what you'll need:
https://modmymods.com/modmymods-raspberry-pi-mini-water-cooling-kit-mod-0171.html
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
Use a proper radiator instead of another Chinesium waterblock.
