Hi Guys!
I'm planning to buy a new PC and i want to build a water cooling system in it.
I don't know witch one is the better option:
a, One Loop System: CPU GPU 2x480mm radiators and another 360mm rad.
          I'm afraid of that one pump won't be able to handle all 3 rads.
b, Two Loops System: CPU and a 360mm rad - GPU and 2x480mm rads.
          I also afraid of thet is I put CPU and GPU in one loop, then the second block will get warm water instead of cool fresh from the rads.
Witch one is better choice?
Witch of my fears is true?
Witch brand have the best cooling staff (pump, reservoir, rad, etc.)?
Witch is better, pump and reservoir or two in one pump & reservoir?
Planned PC Specs:
Corsair Series Obsidian 1000D
RTX 2080 ti
i7-9700k
Some Thermaltake Cooling Staff
https://linustechtips.com/topic/1076955-single-or-dual-loop-cooling-system/
You could always do res -> pump -> rad -> CPU -> rad -> GPU-> rad -> res
That'd be a neat configuration for it. (or some other configuration with a rad between the CPU and GPU in the loop. I'm no loop configuration expert.)
I really wouldn't worry much about having both the CPU and GPU in the same loop. If you did two loops, you'd need two reservoirs and two pumps, so keep that in mind. (More vibration from pumps, more space taken up, etc..)
36 minutes ago, csokifagyi000 said:
Hi Guys!
Planned PC Specs:
RTX 2080 ti
i7-9700k
I have all my things in the same loop. GPUs don't go past 48C during load. (specs in sig)
Main PC:
CPU: Intel Core i9 14900KS SP 109 (125P-79E) (6.1Ghz P-Cores 4.8Ghz E-cores) MC SP 88
CPU Voltage: LLC6 1.43V
Cooled by: Supercool Direct Die 14th gen full nickel
Motherboard: Z790 ASUS Maximus Apex Encore
RAM: GSkill TridentZ 2x24GB DDR5 8800Mhz Watercooled
GPU: RTX 5090 Palit OC with Alphacool Core Waterblock
Case: TT P3
Storage: 4x 2TB Sarbent Rocket Plus Gen 4.0 NVMe, 1x External 2TB Seagate Barracuda (Backup)
PSU: Corsair AX1600i with custom black and red cables with 2x Corsair 5V+ Load Balancer
Display: Samsung Oddysey G9 57" 240Hz Ver. 7680x2160 and
2x ASUS XG17AHP 240hz 17"
Fan Controllers:  6x AquaComputer Octo
Cooling: Three Custom Loops:
1st Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for GPU only cooling with 2x Koolance QDC3, red coolant
2nd Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for CPU only cooling with 2x Koolance QDC3, purple coolant
3x 360mm PE EKWB CoolStream
3rd Loop: 1x 240mm PXE CoolStream radiator with 1x EKWB Revo D5 pump (RAM ONLY) - Back of the case
2nd Main PC is same as above, except Display is Philips Evnia 49" 5120x1440 240hz QD-OLED, 48GB 8400Mhz RAM, 8TB NVMe
1st LaptopMSI Titan HX18 Dragon EditionRTX 5090 175W, Core Ultra 285HX,  128GB of RAM @5600Mhz / 96GB @6400Mhz
8TB of NVMe - GPU and CPU with LM on, Llano V12
2nd Laptop: MSI Raider 18HX, RTX 5090 175W, 9955HX3D, 128GB DDR5 @5600Mhz, 8TB NVMe, CPU and GPU LM on, Llano V12
3rd Laptop: MSI Titan 18HX, RTX 4090 175W, 14900HX, 224GB DDR5 @3600Mhz, 8TB NVMe
HTPC:
CPU: Intel Core i9 14900K (SP99 P111 E76), CPU Voltage: 1.33V, Cooled by: Supercool Direct Die 12th gen full nickel, Motherboard: Z790 Apex
RAM: GSkill TridentZ 2x24GB DDR5 8000Mhz CL40, GPU: RTX 5090 Palit Gamerock with Alphacool Waterblock,  Case: Corsair 6500D, Storage: 3x2TB PM9A1 Samsung NVMe Gen 4
WiFi: Wifi 6E Built in, PSU: AX1600i Corsair Titanium, Display: Philips Evnia 49" 240Hz OLED, Fan Controllers:  1x DH-10 DeepCool and Deepcool RGB hub, Loop: 2x 360mm XE CoolStream radiator, 1x 360mm PE Coolstream Radiator, 1x 240mm XE CoolStream Radiator, Revo D5 EKWB Pump, 19x Corsair 120ML RED LED fans 2000RPM
If you are gonna go through the trouble of a dual loop, might as well either do it or put two pumps on a single loop.
Dont see how warm fluid would effect the second block. That’s why the radiators are there. Dual is easier to maintain but gonna cost more in each way. I’d do it if you have the room for it. Or keep it simple and do a single loop and hope it can look better.
2x480+360 what are you cooling? A nuclear reactor?
It is a massive case and you need to feel it up with something, however you are not running a 500watts cpu like a 32 core threadripper or 9980xe nor multi GPU setup.
one d5 pump is enough for you loop. You better off to invest in something like aquaero or commander pro to control your fans and pump.
CPU: i7 8700K OC 5.0 gHz, Motherboard: Asus Maximus VIII Hero (Z170), RAM: 32gb Corsair Vengeance RGB 3200 mHz, GPU: Asus Strix OC gtx 1080ti, Storage: Samsung 950pro 500gb, samsung 860evo 500gb, 2x2Tb + 6Tb HDD,Case: Lian Li PC O11 dynamic, Cooling: Very custom loop.
CPU: i7 8700K, Motherboard Asus z390i, RAM:32gb g.skill RGB 3200, GPU: EVGA Gtx 1080ti SC Black, Storage: samsung 960evo 500gb, samsung 860evo 1tb (M.2) Case: lian li q37. Cooling: on the way to get watercooled (EKWB, HWlabs, Noctua, Barrow)
CPU: i7 9400F, Motherboard: Z170i pro gaming, RAM: 16gb Corsair Vengeance RGB 3200 mHz, GPU: Sapphire Vega56 pulse with Bykski waterblock, Storage: wd blue 500gb (windows) Samsung 860evo 500Gb (MacOS), PSU Corsair sf600 Case: Motif Monument aluminium replica, Cooling: Custom water cooling loop
Quote
If you have more radiator capacity you can run your fans with a lower rpm and the system is quieter.
I would recommend connecting  all components in one loop.
CPU: Ryzen 7 7800X3D,  RAM: 64 GB Gskill Trident Z DDR5 @6200 Cl32, GPU: Asus RTX 4090 Strix OC, Pump: 2 Aquacomputer D5 Next @ 60% (~160 l/h), Radiators: 2 Mo-Ra3 360 and 1 XSPC  RX360V3 with 21 fans @650 RPM.
It's exactly what happened from my experience: During graphically-intensive games where the CPU was barely being used the GPUs (always SLI...) would warm up and hit their steady-state temperature.  The CPU would as well, and get to nearly the same temperature.
Likewise, if I was running a CPU-intensive job where the GPUs weren't being used much, they'd get warmed up by the water coming off the CPU.  It didn't really seem to matter how I ordered the components, even with wedging a radiator or two between them.  It really seemed like the three chips were looking for a temperature equilibrium.
When I moved to two independent loops with two pump/res combos, that "equilibrium" stopped.  The GPUs' temps increased independently of the CPU's, and vice versa.  As you point out, a two-loop setup is far more flexible than a single loop.  It becomes more so when you consider maintenance, changing parts out, adding/removing GPUs or CPUs, etc.  One real simple "for instance" - When I purchased my new GPUs it was prior to EK releasing the blocks for them (thankfully, it wasn't too long).  But because I had a single loop in the system, I couldn't really swap the GPUs out without completely re-working the tubing in the system.  But if I'd had a double-loop at the time, I could have pulled the old GPUs out, disconnected the pump from the electrical system, and temporarily used the new GPUs on air.
It's that sort of flexibility that has convinced me to keep with double loops from now on.  Also, to someone else's point: there's no such thing as "too much radiator".  More surface area means more fans, and more fans means ssllllooowwwwerrrrr fans.  Which means quiet .. sshh shhh  QUIET!! fans.
Editing Rig: Mac Pro 7,1
System Specs: 3.2GHz 16-core Xeon | 96GB ECC DDR4 | AMD Radeon Pro W6800X Duo | Lots of SSD and NVMe storage |
Audio: Universal Audio Apollo Thunderbolt-3 Interface |
Displays: 3 x LG 32UL950-W displays |
Gaming Rig: PC
System Specs:  Asus ROG Crosshair X670E Extreme | AMD 7800X3D | 64GB G.Skill Trident Z5 NEO 6000MHz RAM | NVidia 4090 FE card (OC'd) | Corsair AX1500i power supply | CaseLabs Magnum THW10 case (RIP CaseLabs ) |
Audio:  Sound Blaster AE-9 card | Mackie DL32R Mixer | Sennheiser HDV820 amp | Sennheiser HD820 phones | Rode Broadcaster mic |
Display: Asus PG32UQX 4K/144Hz displayBenQ EW3280U display
Cooling:  2 x EK 140 Revo D5 Pump/Res | EK Quantum Magnitude CPU block | EK 4090FE waterblock | AlphaCool 480mm x 60mm rad | AlphaCool 560mm x 60mm rad | 13 x Noctua 120mm fans | 8 x Noctua 140mm fans | 2 x Aquaero 6XT fan controllers |
The rads are not the most resistant, the waterblocks are. In any case, a single D5 pump will go through that setup without much problems.
The way LC cooling works, in a loop like this, the temp will more or less equalize and the order will not matter.
When is it good to go for double loop?
1. You have a huge case (like the biggest Corsair or Caselabs cases) and don't know what to do with spare space
2. You rutinely put a 100% load on your CPU AND GPU's
In other instances it's better to go for single loop (for instance, in gaming you typically use between 20-30% of your CPU and 90+% of your GPU so doing a double loop will actually waste cooling performance of the rads from the CPU loop which could've been used by the GPU).
In your specific case, I'd go for double loop simply because Obsidian 1000D is a monster of a case and it will look nice.
Also, with a single GPU and a single CPU mainstream, going for a total of 1320mm of rad capacity will hit a wall of diminishing returns HARD. With that much cooling capacity, basically do what you want and what looks nice.
CPU: i7 6950X  |  Motherboard: Asus Rampage V ed. 10  |  RAM: 32 GB Corsair Dominator Platinum Special Edition 3200 MHz (CL14)  |  GPUs: 2x Asus GTX 1080ti SLI
Storage: Samsung 960 EVO 1 TB M.2 NVME  |  PSU: In Win SIV 1065W
Cooling: Custom LC 2 x 360mm EK Radiators | EK D5 Pump | EK 250 Reservoir | EK RVE10 Monoblock | EK GPU Blocks & Backplates | Alphacool Fittings & Connectors | Alphacool Glass Tubing
Case: In Win Tou 2.0  |  Display: Alienware AW3418DW  |  Sound: Woo Audio WA8 Eclipse + Focal Utopia Headphones
Don't see why it would matter at all. So the temps would go up a bit? Doesn't effect anything at all unless you have bad fan profiles. Better cooling and better profiles eliminate that kind of issue. Having one loop with a silent profile is the same as having two loops with the same profile. Unless you need to see unused devices at their idle temps all the time, somehow making the idle devices perform better.
But yea, if you wonna service half the system for that sure. I would do that too if I had the room to cool my stuff on two loops. Perfect for that reason and that one alone.
