Help
Go to solution Solved by HairyPotter,
25 minutes ago, Amforev said:
Just a pendrive with Linux on it, it's super easy to do it.
Here is how:https://manjaro.org/support/firststeps/#making-a-live-system
Good news the buyer folowed these simple steps https://www.reneelab.com/fix-windows-10-defaultuser0-problem.html and got it fixed thank you guys anyways for helping! Love this community
1 minute ago, HairyPotter said:
Yeah says incorrect pretty much tried all the default passwords
Tried 'trs10' yet?
Anyways, it's probably best to just reset Windows at this point. Or use some Linux distro to reset the password, but I don't know how the latter goes exactly.
https://linustechtips.com/topic/1076335-help/#findComment-12674454
8 minutes ago, HairyPotter said:
So just sold my gaming laptop to somemone (acer nitro 5) and when they turned on the laptop, an account called defaultuser0 they told me that there is a password, but there isn't one, is this some problem with windows? I need help to help him fix it please
Reinstall windows otherwise via bootable USB ?
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
https://linustechtips.com/topic/1076335-help/#findComment-12674456
Just now, Minibois said:
Tried 'trs10' yet?
Hoe do i tell him to reset windows if its locked by the password?
https://linustechtips.com/topic/1076335-help/#findComment-12674459
Reset the password, probably.
Or completely reinstall it. The former might be seen as hacking.. depending on where you're from.
https://linustechtips.com/topic/1076335-help/#findComment-12674471
3 minutes ago, HairyPotter said:
How do i tell him to do that?, He says he is stuck on the loading screen, it keeps just loading now
He needs to create one.
download windows 10 from Microsoft and they also have a guide to make a bootable USB.
Once he’s done that go into the bios and set USB as booting device
https://linustechtips.com/topic/1076335-help/#findComment-12674475
Do you have links that list the steps and help? He is pretty new to this
https://linustechtips.com/topic/1076335-help/#findComment-12674477
How do i reset?
There are some Linux distros that can do this, but that might fall under hacking, so not recommended. Especially for the not so tech savy.
The basics steps are:
Make a bootable USB thumbdrive (go to Google, go to the Windows 10 website, follow the steps and get a bootable USB drive)
Boot from this drive (change the boot order in the laptop's BIOS)
Install Windows
That's it.
https://linustechtips.com/topic/1076335-help/#findComment-12674483
And does he nees to activate windows after the reset? Windows came with the laptop so that would be inconvenient
https://linustechtips.com/topic/1076335-help/#findComment-12674485
https://www.microsoft.com/en-ca/software-download/windows10ISO
https://www.microsoft.com/en-us/download/windows-usb-dvd-download-tool
https://linustechtips.com/topic/1076335-help/#findComment-12674488
Install Windows
That's it.
Trust me no hackers im pretty sure, does reinstalling windows require a new key? Windows came with the laptop so that can be inconvenient
https://linustechtips.com/topic/1076335-help/#findComment-12674493
No, the key should be tied to the laptop motherboard, so it should activate itself after reinstall.
Just when you are at the step where it asks for a windows key, just click the absolutely tiny button labeled "i don't have a key"
I only see your reply if you @ me.
https://linustechtips.com/topic/1076335-help/#findComment-12674504
After clicking i dont have a key that should work?
https://linustechtips.com/topic/1076335-help/#findComment-12674515
Hoe do i install windows when its already installed btw?
https://linustechtips.com/topic/1076335-help/#findComment-12674516
yes
Like @Stormseeker9 told you. Just boot to the Windows installer usb (media creation tool) and then click "install windows"
https://linustechtips.com/topic/1076335-help/#findComment-12674544
8 minutes ago, Origami Cactus said:
yes
Well the person I'm trying to help is a newbie so he doesn't know much, if its not a hassle can you please make a detailed list so i can send him? With links and instructions
https://linustechtips.com/topic/1076335-help/#findComment-12674582
This method should work:
-> make bootable linux flash drive
-> boot from it
-> go to this location volume(capacity of the volume) -> Windows -> System32
-> rename file called "sethc" (for example to "sethc7")
-> copy cmd file
-> paste it to the same loccation
-> rename coppied file to "sethc"
-> reboot the computer
-> boot from windows
-> at login screen spam "shift" a copule of times until terminal pops out
-> write "net user nameoftheuser * " in terminal then press "enter"
-> press enter once more
-> press enter again
-> write "exit" in the terminal and press "enter"
-> password should be removed
This method works with Windows 7 so it should work with Windows 10 either.
https://linustechtips.com/topic/1076335-help/#findComment-12674594
-> boot from it
-> copy cmd file
Bootable linux drive? Whats that
https://linustechtips.com/topic/1076335-help/#findComment-12674611
Press whichever button is bound to the BIOS menu while setting up and change the boot order to external usb driveand boot into the windows usb by retsarting and finish the setup
Current PC (Second Build) : CPU: Ryzen 5 1600 (OC @3.8GHz, sometimes pushed to 4GHz) RAM: 16gb Corsair Vengeance RGB Pro DDR4-2666 (OC @2733Mhz, sometimes pushed to 2800 for testing purposes)   GPU: PowerColor Radeon RX570 8gb MOBO: ASRock B450m Pro4 SSD: Inland 120gb HDD: 1tb Seagate Barracuda PSU: Cooler Master Masterwatt 500w Lite Case: NZXT H500 OS: Arch Linux+ KDE Plasma [Desktop Environment] & Windows 10 Pro [Broken due to grub 50% of the time]
Accessories: Mouse: Alienware AW958 Elite Keyboard: Corsair K63 Wireless  Headphones: Samsung Level On Pro
Phone (waiting on arrival): Samsung Galaxy Note 9
https://linustechtips.com/topic/1076335-help/#findComment-12674619
Not worth the trouble
https://linustechtips.com/topic/1076335-help/#findComment-12674644
