ATX case suggestions, Zen 2 planning
porina
Given it is not long to go, thought I might pick up a case in advance, as it is one of the few areas that don't age. As usual there is "too much choice" so opening it for suggestions.
Mid-tower-ish size, no bigger than necessary to meet below.
ATX mobo
Easy to access components when tinkering.
Behind mobo tray cable routing options, with enough room to get cables there
Window preferred but not essential. Acrylic is fine. Would like to avoid glass this time around.
High airflow preferred, say two each substantially unobstructed intake + exhaust fans.
Components will be air cooled, don't care about water fittings
Don't want a PSU shroud, should be removable if present.
RGB don't care
Should have mounts suitable for at least three 2.5" drives, 4 or more preferred. If not native, a 3.5" bay would count as two 2.5".
Bonus points if the design is interesting. I don't know how to define "interesting" other than I'll know it when I see it. I don't like large areas of unpainted aluminium or wood.
Budget: not a problem, but don't go insane. Lian Li is probably out.
Random thoughts: I'm overdosed on glass and RGB. In Win make some interesting cases, but the airflow generally sucks. Most things seem a bit boring in a sea of plastic.
Gaming system: R7 7800X3D, Asus ROG Strix B650E-F Gaming Wifi, Thermalright Phantom Spirit 120 SE ARGB, Corsair Vengeance 2x 32GB 6000C30, RTX 4070, MSI MPG A850G, Fractal Design North, Samsung 990 Pro 2TB, Acer Predator XB241YU 24" 1440p 144Hz G-Sync + HP LP2475w 24" 1200p 60Hz wide gamut
Productivity system: i9-7980XE, Asus X299 TUF mark 2, Noctua D15, 64GB ram (mixed), RTX 3070, NZXT E850, GameMax Abyss, Samsung 980 Pro 2TB, random 1080p + 720p displays.
https://pcpartpicker.com/product/qvF48d/be-quiet-silent-base-801-window-silver-atx-mid-tower-case-bgw30
https://pcpartpicker.com/product/FjQG3C
Silent Base 801 perhaps.
slight airflow concern and i believe you can remove the PSU shroud, but i could be misstaken.
allows for inverted setup if wanted.
@TVwazhere proabbly has a good suggestion.
Front airflow concern, similar design to solid front cases although not immediately obvious how much room there is from pics. Wont rule it out. Bonus points for invertable case. I was undecided on mentioning that, as I thought it would limit the choice too much.
In random searching this caught my eye:
https://www.coolermaster.com/catalog/cases/mid-tower/masterbox-q500l/
Looks a bit cramped to work in, don't like the window mount, and not sure about the holes for airflow, but it looks interesting at least. If they did a bigger version that would be nice. Maybe one for a different build another time.
its a noise concerned case. so its probably not the best.
Oh snap thats me!
Coolermaster Master Case H500 would be a good start, though it does have glass and RGB, the RGB can be turned off. The Half PSU shroud has to be removed anyways to install your PSU (and it's really easy to do)
Pure base 600 would be a bit better than the 801, though it's not airflow focused at all, and you'd need to have the "performance mode" set to levels 2 or 3 on the built in controller to get decent airflow
Woulda like to include the Original Masterbox 5 but it seems to have bene discontinued in favor of all the closed off front panels of the white version, pro's and lite >:( At least the Mastercase MC500 is still for sale (and actually seems to fit everything you want really well)
10 minutes ago, porina said:
The Original Q300L mATX case that's based off has an 80-20 steel to hole ratio, so it's not actually a great airflow front. The ATX version moved the PSU to the front so a lot of the airflow that wasnt there got cut off even more so. The result has been very poor reviews overall, so I would definitely skip this one
CPU i7-4790k    Motherboard Gigabyte Z97N-WIFI    RAM G.Skill Sniper DDR3 1866mhz    GPU EVGA GTX1080Ti FTW3    Case Corsair 380T
Storage Samsung EVO 250GB, Samsung EVO 1TB, WD Black 3TB, WD Black 5TB    PSU Corsair CX750M    Cooling Cryorig H7 with NF-A12x25
It looks familiar, especially internally, and worked out it's because I have a Masterbox 5 already. While that has a good front area, it seems a bit lacking for where the air goes out. H500 at least has top vent also now.
Functionally it fits most of the requirements, but it looks a bit... meh. #firstworldproblems
