I've got a GTX 780 and a Quadro K600.
I'd like to run the Quadro alongside my 780 and use it for NVENC encoding to take the load off of my 780 and hopefully fix my FPS problem while streaming. Problem is, I can't find much conclusive on the internet about running a Quadro and GeForce card in the same system.
I did find one thing that said if they're the same architecture, the odds of it working are higher. Both of my cards are Kepler-based, which got me wondering just how easily I could get the Quadro running alongside the 780.
Unless I'm crazy, the drivers for my 780 should theoretically work with the K600, right?
https://linustechtips.com/topic/1071665-quadro-and-gtx-same-pc/
aren't workstation drivers a bit different? You can just check what driver Nvidia's site recommends for the two cards and whether they are the same.
Desktop benching:
https://linustechtips.com/topic/1071665-quadro-and-gtx-same-pc/#findComment-12635753
They are a little different. I don't need the full drivers for the K600 though, I just need it to be able to do NVENC encoding.
https://linustechtips.com/topic/1071665-quadro-and-gtx-same-pc/#findComment-12636402
Then should try Geforce drivers. Workstation drivers dont have Geforce Experience stuff as far as I know which includes shadowplay. I guess it doesnt take away NVENC, but just in case it does...
Desktop benching:
https://linustechtips.com/topic/1071665-quadro-and-gtx-same-pc/#findComment-12636451
8 hours ago, Electronics Wizardy said:
I think all the nvidia drivers are the same, and they change the features depending on the detected card.
But if you have the hardware, you might aswell just test it.
8 hours ago, Daniel Z. said:
Should work, Nvidia drivers are usually the same/similar especially for same generation cards.
Windows threw a hissy fit and wouldn't do anything with the K600 installed. Not sure if I should wipe drivers and then install K600..?
https://linustechtips.com/topic/1071665-quadro-and-gtx-same-pc/#findComment-12636453
Just now, Daniel Z. said:
I would DDU then try the Creator Ready drivers.
Alright, I'll try that in a bit.
https://linustechtips.com/topic/1071665-quadro-and-gtx-same-pc/#findComment-12636578
