I need some help with DLL
shirou
I get an error when I run Social-Club-Setup. But I don't know which of these missing DLL files came from which runtime. help me please!!!
This is my log file⬇️⬇️⬇️
Social-Club-Setup.txt
All API and EXT are not loading because lower level did not load properly so excluding those leave you with these :
- EMCLIENT.DLL  A spyware of some sort, it gather local data to send to someone somewhere. People usually hate these things. Might have been deleted/quarantine by your anti-virus for those reasons.
- IESHIMS.DLL : This one is well known to have issues of different kind. My bet is on that one has i have seen a couple handful time this issues when i was doing tech support. The fix is not always as simply a updating it.
- HVSIFILETRUST.DLL : don't know this one but my guess from it's name it must be DRM or Hash tools for stability. Since it most likely scan files it might have been deleted/quarantine by your anti virus
Let me guess, you have a pirated copy of GTA V?
Sudo make me a sandwich
1 hour ago, Franck said:
所有API和EXT都没有加载,因为较低级别没有正确加载,所以排除那些离开你
- EMCLIENT.DLL  : 某种间谍软件,它收集本地数据以发送给某个人。人们通常讨厌这些东西。出于这些原因,您的防病毒软件可能已被删除 /隔离
- IESHIMS.DLL:众所周知,这个问题有不同类型。我的赌注是,当我在做技术支持时,我已经看到了几个问题。修复并不总是简单地更新它。
- HVSIFILETRUST.DLL:不知道这个,但我猜它的名字必须是DRM或Hash工具才能保持稳定。由于它很可能扫描文件,因此可能已被您的反病毒删除/隔
McAfee does not have any program which is isolated.It may be the reason the windows ver 1903
delete everything and reinstall. It is better, quicker, and safer than manually hunting down dll from the webs.
