Planning to build a Pc need help
Go to solution Solved by Herman Mcpootis,
1 hour ago, Chichichi said:
architectural softwares , CAD, lumion or vray rendering. and other editing softwares
,a good display for designing.
grab something like this, you may need to swap a few parts around if you can't get them in the phillipines.
PCPartPicker Part List
CPU: Intel - Core i9-9900K 3.6 GHz 8-Core Processor  ($484.99 @ Amazon) wait for zen 2 if possible.
CPU Cooler: Cooler Master - MasterLiquid ML360R RGB 66.7 CFM Liquid CPU Cooler  ($149.73 @ OutletPC)
Motherboard: Gigabyte - Z390 AORUS PRO ATX LGA1151 Motherboard  ($169.99 @ Amazon)
Memory: G.Skill - Aegis 32 GB (2 x 16 GB) DDR4-3000 Memory  ($131.98 @ Newegg)
Storage: HP - EX920 1 TB M.2-2280 Solid State Drive  ($119.89 @ OutletPC)
Storage: Toshiba - X300 4 TB 3.5" 7200RPM Internal Hard Drive  ($104.89 @ OutletPC)
Video Card: EVGA - GeForce RTX 2080 Ti 11 GB Black Video Card  ($1091.98 @ Newegg)
Case: Fractal Design - Define C TG ATX Mid Tower Case  ($89.33 @ Amazon)
Power Supply: Corsair - RMx (2018) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($109.99 @ Amazon)
Monitor: Acer - Predator X34 34.0" 3440x1440 120 Hz Monitor  ($791.89 @ OutletPC)
Total: $3244.66
Generated by PCPartPicker 2019-06-05 01:36 EDT-0400
  Reveal hidden contents
I need help, i want to build a pc that is good for Architectural Softwares, video rendering, and also good for gaming. What parts should i get? Budget 5000$ - 3000$ worth build
what programs will you be using?
Total: $3244.66
thank you so muchhh guys for your  helpp much appreciated
