Using RGB splitter on ARGB port
Saaif
Can I use a 4 to 1 RGB splitter on my ARGB port to connect 4 ARGB fans?  I've one 4 to 1 RGB splitter which I am not using right now thus I want to use that RGB splitter on my ARGB port of the motherboard,need the exact answer,thanks in advance
No, RGB is 4 pin, ARGB is 3 pin. It will not work.
"Black Out"
1tb Samsung 970 Evo | 2x 2tb Crucial MX500 SSD | Fractal Design Meshify S2 | Corsair HX1200 PSU
Dedicated Streaming Rig
 Ryzen 7 3700x | Asus B450-F Strix | 16gb Gskill Flare X 3200mhz | Corsair RM550x PSU | Asus Strix GTX1070 | 250gb 860 Evo m.2
My devices are ARGB and splitter is RGB,will it work or not?
Depends on the connector, a 4 pin version will work on the 3 pin that has a space for ARGB. It will just have it so one pin is not used. Just note all the devices will sync together and not allow for individual ARGB control.
Image result for argb header
