Can I use a 4 Pin connector on a 8 Pin motherboard for a Ryzen 5 2600x
18 minutes ago, Kris3456 said:Mine PSU has 1x8 PIN for CPU.
Mine don't for the most part. The Dark Power P8 has an 8pin and the Delta DPS-500QB but neither Bitfenix, Corsair, Cougar, Be Quiet Pure Power 10 have an 8pin. They have a P4+4...
18 minutes ago, Kris3456 said:Abhi1401 said that he have only 1x4 at first, then he has two, but with the "not correct shape".
And that is the Misleading part...
Because the Connector he has is what the PSU Manufacturer call, as said, "P4-4". It looks exactly like that.
And that he only saw one 4pin might be because:
https://m.bonanza.mx/items/like/670081328
...the second part of the Cable was somewhere else.
And yes, it has the "Correct Shape", here is Proof:
You see the Picture on the Corsair Site? That looks exactly like the Pic of the CPU Connector(s) you posted.
18 minutes ago, Kris3456 said:It depends. Even average noname PSU can last 10 years or even more and the best can fail much faster. Always You can replace old or faulty capacitors and use it again for a very long time.
We are _NOT_ talking about an average "no-name" PSU no more, we are talking about a decent quality OEM unit made by one of the best and biggest manufacturers...
I have found some (small) Pictures of the Insides.
And this unit is based on a so called LLC-Resonant Topology with DC-DC. So it is very modern. And decent quality.
The Only issue is that we do not know the quality of the output voltages...
Besides that, its a pretty good quality unit, about as good or better as for example a Corsair CX...
