I'm just wondering how much performance gain your looking at as I'm currently torn between 3 aios the corsair h100i pro, the kraken x62, and the kracken m22 I want go with the sleek nzxt coolers but the corsair is 50 bucks cheaper and dual fan. So if performance gain is minimal I will go with m22. Btw I'm hoping to overclock the i5 8600k.
https://linustechtips.com/topic/1067844-single-vs-dual-liquid-cooling/
The more radiator space, the better heat dissipation.  Personally I think CoolerMaster makes crap AIO fans.  Not sure which ones you will get on the AIO you bought but Ive bought 2 CM AIO's and both came with this janky POS static pressure fan that could barely move air.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
Just now, Tristerin said:
The more radiator space, the better heat dissipation.  Personally I think CoolerMaster makes crap AIO fans.  Not sure which ones you will get on the AIO you bought but Ive bought 2 Corsair AIO's and both came with this janky POS static pressure fan that could barely move air.
Ok so I'm just wondering what it will be in kinda like temps if it's like a 7 degree difference i would go single fan just curious how much performance difference there is on average
it depends what cooler you're already using. typically high end air coolers perform better than AIOs
Yeah I'm using a hyper 212 evo a d I did see linus's vid on it but I am hoping to do heavy overclocking or at least a fair amount of it
well the m22 would perform the worst. From what i've seen from charts in the past, the evga clc 280 is the best performing AIO but somewhat louder than others
Again, for the best overclocking, i would go with a beefier air cooler like the dark rock pro or noctua d-15
