Need advice for airflow improvement
1 hour ago, Arikel0 said:i just put in dissable turbo in the bios and this is the new max of voltage
Edit: I dont know how set the right ammount of voltage, id you have a summis guide will be apreciated.
There's no need to disable turbo.
In the Ai Tweaker tab, disable Asus Multicore Enhancement.
When you scroll down in the same section, you can set CPU Core Voltage to Manual Mode. There's a box that shows up where you can input the voltage setting. As mentioned, you can try 1.1v first. https://youtu.be/ioxDMAe2sPs?t=939
Afterwards, press F10 to save settings and reboot.
Try a stress test like OCCT to test for stability and load temps. If it crashes, you can raise the voltage a bit to 1.15v and try again. Higher voltage can help increase stability but also raise temps so the optimal setting is as low as possible while maintaining stability. If you're unlucky, it may require going up to 1.2v but your temps should be lower than when the voltage was at 1.357v
