Wich 27-32" 1080p Freesync + HDR Screen? (TV/Monitor) for 400€
Stefan Payne
I'd like to get a new Screen
The minimum requriement:
  • Freesync support, ~40Hz minimum, lower preferred, don't care about "high fps".
  • HDR support - on Playstation especially, XBox/PC as well
  • 2x HDMI + DP
  • 27": 1080p or 1440p, 2160p: 31,5" minimum
  • 16:9 Aspect ratio
  • IPS preferred but can live with *VA, NO TN!
  • I prefer non curved screens (for now)
  • VESA Mount (to screw it against the Wall)
  • max. Price: 400€, if not avoidable 500€
Region: Germany
Preferred Shops: Mindfactory, Caseking, Reichelt. Other possibilitys: Caseking, Notebooksbilliger
I've looked a bit and I'm tending towards 4K/31,5", but can't find something that looks awesome enough for that price.
But it doesn't seem like they suport HDR. At least when Freesync is active, if I understand the Specs correctly.
For example:
https://geizhals.de/benq-ew3270u-9h-lgvla-tse-a1790472.html?hloc=at&hloc=de
https://geizhals.de/viewsonic-vx3211-4k-mhd-a1850394.html?hloc=at&hloc=de
Or they don't list the Freesync Range...
"Hell is full of good meanings, but Heaven is full of good works"
  • Freesync support, 40Hz minimum, lower preferred, don't care about "high fps".
  • 2x HDMI + DP
  • 16:9 Aspect ratio
Region: Germany
For example:
why freesync?
Does PS4 support HDR?
1 minute ago, Firewrath9 said:
why freesync?
Because I like to play at higher settings and thus often under 60fps.
PS4 PRO does.
And I have an option for that.
Oh, boy.  I do not envy your search.  I hope you find a good deal.  Godspeed.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
So you're saying the product I'd like to buy doesn't exist (yet)??
Add IPS to your research
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
Freesync + HDR + 31.5 inch? GL
I'd settle for a 27" FullHD Screen instead, if that is all that's possible.
The Freesync 2 HDR Screens look interesting, those are 27" 1440p though. But min frequency is at 48Hz...
OK, so I decided to settle for a 27"/1080p screen
Any recommendations??
"And I'll be damned if I let myself trip from a lesser man's ledge"
