Best headphones for around 100 dollars
sperkowsky
Ok so I'm looking for new headphones
I want them for general gaming and editing.
These are going to be used in conjunction with my blue snowball so I do not need.
I do have a good relationship with sennheiser (done some review work for them) and I may be able to get a deal on a pair of them.
Also if possible if the headphones are cheaper maybe give me a
Suggestion on something to power them better like a USB dac or something(not an audio guy)
I'm selling my beats solos for them (yes I know they are a peice of crap learned the hard way)
The overly recommended ATH-m50's can be bought for $100 or sometimes even less
    CPU: 3930k  @ stock                                  RAM: 32GB RipjawsZ @ 2133Mhz       Cooling: Custom Loop
MOBO: AsRock x79 Extreme9                      SSD: 240GB Vertex 3 (OS)                     Case: HAF XB                     LG 34um95 + Ergotron MX Arm Mount - Dual Review
  GPUs: Gigabyte GTX 670 SLI                     HDD: 1TB WD Black                                PSU: Corsair AX 860                               Beyerdynamic - Custom One Pro Review
I recomend the v-moda crossfade lp, around 120$
any sennheiser 500 series :)
Current Build :
CASE: Fractal Design R4 w/Window CPU: Intel 4930K,  RAM: 16GB Ripjaws Z 2133Mhz  Cooling: H100i  MotherBoard: Asus P9x79 Pro , PSU: CS750M   Storage: 2x Samsung 840 Pro 256Gb , 1Tb Seagate Barracuda, 500GB WD Black,  Graphics: Gigabyte GTX 780 Windforce 3GB,  Monitors: AOC G2460PG ( G sync monitor), Edge10 24" 1080p , 24" 1680*1020p monitor ( LCD)  Microphone: Blue Yeti  Keyboard: Cougar 700k  Phone: Samsung Note 3  Headphones: Sennheiser HD598
Laptop:
 CPU:
4710MQ  Ram: 8GB 1600MHz Storage:120Gb 840 Evo + 1Tb 5400Rpm HDD  Graphics: GTX 850M 2GB   Screen: 1080p IPS
m50s are horrible for positional games,
great positional budget headphones:
superlux hd681 I recommend new earcups, not the evos
panasonic htf600s
cals, denon d1000 clones I believe,
nvx xpt100, fischer fa 003 clones,
ad700s,
if you can get the 558's, they are a great choice. However, if you're a basshead, I'd rather go with the M50's out of those two. The Sennheisers are really comfortable though, so right now, I'd rather go with the 558's. or the 518's if the 558's are a little out of reach, supposedly they sound very similar.
Reviews: JBL J33i   M50s   SRH440   Soundmagic PL50
going with the 558s I'm not bass head I mean I like bass but I usually don't listen that much to music and in gaming I found it's better to have overall clean sound. Besides I have a good relationship with sennheiser from YouTube so I will probably get a good deal on them
hd558 are nice, you can remove the tape in the ear cups to make them sound pretty damn similar to the hd598s, same drivers/etc
I still prefer my fischer fa003 clones or cals for the 0-200 range, I do own the hd558s,
I rotate my headphones bi weekly to appreciate their uniqueness, but as that being stated everything is subjective my ears isnt yours
The Sony MDR-V6 are an awesome pair for under $100 (usually around 85) particularly for editing/audio work, and even for gaming. That being said, I'm very partial to ATH-M50's (for bass) or Sennheiser HD558's (for comfort) in 'approximately' that price range. AKG K 240's are also 'ok' in that price range. I've had limited experience with them and I hear their quality isn't what it used to be, but good for the price.
I see you made your choice, GOOD CHOICE! :)
Case: Corsair 750D | CPU: Intel i7 4770k | Video Card: Gigabyte WF3 780 Ti 3GB | RAM: 16gb Corsair Vengeance LP | Motherboard: MSI Z87-G45 | Hard Drives: Samsung 840 EVO 250gb SSD / 1TB WD Black / 2TB Seagate Barracuda / 2x2TB WD Green | PSU: Corsair RM750 | Cooler: Corsair h100i w/ Noctua NF-F12 x2 | DAC: O2 Amp/Dac Combo w/ RCA from Mayflower Electronics | Headphones: HiFiMAN HE-400 | Microphone/Input: AudioTechnica AT2035 w/ Scarlet 2i2 Keyboard: Ducky Shine 2 w/ Custom Keycaps | Mouse: Logitech G502 | Monitor: QNiX QX2710LED 1440p PLS & WASABI-MANGO QH275 27" 1440p S-IPS
