Monitor freezing issue
Eastman51
I have an Asus VS247H-P monitor that has started to straight up not work. It will display output, but only a static image. I've tried using different cables (HDMI to Displayport, HDMI to HDMI, HDMI to DVI) and different ports on the GPU, but it always shows a static image. The mouse can scroll across it, but nothing displayed on screen can be interacted with. I've also tried the Win+Ctrl+Shift+B combo to refresh the display drivers, but that doesn't do anything either.
My Nvidia drivers are completely up to date, Windows has one of those "seeker" updates that I'm going to try out, and I've tried every possible port and cable combo I can (I have an Asus Strix 2080, so no DVI or VGA ports; and I don't have DVI to DP or VGA to HDMI/DP, or USB C adapters for displays). If Windows update/a reboot don't fix the issue, I'll try a DDU and clean install of my drivers. If that doesn't work, I'm going to assume its the display; if this is the case, is it fixable? If so, how complicated of a repair is it? Or do I just have to get a new monitor?
Edit: After the Windows update the monitor seems to be working fine. I believe this has happened in the past (on different driver and Windows versions), so it may start to become a recurring issue. I brought my PC out of sleep mode when I got home today, and I think that the other occurrence(s) of this also involved sleep mode.
Primary PC: - https://pcpartpicker.com/list/8G3tXv (Windows 10 Home)
HTPC: - https://pcpartpicker.com/list/KdBb4n (Windows 10 Home)
Server: Dell Precision T7500 - Dual Xeon X5660's, 44GB ECC DDR3, Dell Nvidia GTX 645 (Windows Server 2019 Standard)
*SLI Rig* - i7-920, MSI-X58 Platinum SLI, 12GB DDR3, Dual EVGA GTX 260 Core 216 in SLI - https://pcpartpicker.com/list/GHw6vW (Windows 7 Pro)
HP DC7900 - Core 2 Duo E8400, 4GB DDR2, Nvidia GeForce 8600 GT (Windows Vista)
Compaq Presario 5000 - Pentium 4 1.7Ghz, 1.7GB SDR, PowerColor Radeon 9600 Pro (Windows XP x86 Pro)
Compaq Presario 8772 - Pentium MMX 200Mhz, 48MB PC66, 6GB Quantum HDD, "8GB" HP SATA SSD adapted to IDE (Windows 98 SE)
Asus M32AD - Intel i3-4170, 8GB DDR3, 250GB Seagate 2.5" HDD (converting to SSD soon), EVGA GeForce GTS 250, OEM 350W PSU (Windows 10 Core)
*Haswell Tower* https://pcpartpicker.com/list/3vw6vW (Windows 10 Home)
*ITX Box* - https://pcpartpicker.com/list/r36s6R (Windows 10 Education)
Dell Dimension XPS B800 - Pentium 3 800Mhz, RDRAM
In progress projects:
*Skylake Tower* - Pentium G4400, Asus H110
*Trash Can* - AMD A4-6300
*GPU Test Bench*
*Pfsense router* - Pentium G3220, Asrock H97m Pro A4, 4GB DDR3
