Does anyone know if you can mod the cooler master mastercase h500m to fit a 3x140mm radiator in the front, just like you can do with the h500p?
Planning on a 2x140mm rad on top and a 3x140mm rad in the front.
If yes, this will set my decision for which one of those two to get. :S
https://linustechtips.com/topic/1065449-mastercase-h500m-modding/
Internally the frames of the H500P and H500M are pretty similar, so I would expect anything you can do the the H500P you can do to the H500M.
Image result for h500p interior
-Topic moved to Case Modding-
Main thing is height as the added end tanks for both ends in a radiator it may lead to the 140mm fans fitting in the dedicated mounts but not having enough clearance for the rad itself. The mounting points for those fans are also somewhat restrictive and doesn't allow you to shift the whole front cooling array up or down much.
