2 intake fans- how important is it for me to change them?
Solved by Stormseeker9,
2 minutes ago, MrRemnant said:I have the 2 fans in that image installed, Afaik there isn't another slot
Front: 2 x 120 / 2 x 140mm
Top: 1 x 120mm (1 Aer F120 Case Version included) / 1 x 140mm
Rear: 1 x 120mm (1 Aer F120 Case Version included)
you can place 2 fans in the front as intakes and have your current two ones as exhaust. (My advice)
Featured Topics
BTSHalfLifeAndGmodFan2003 ·
Posted in Storage Devices4 -
1
Abaris ·
Posted in Troubleshooting3 -
2
6
2
SpookyCitrus ·
1
Hey_AND1 ·
Posted in Peripherals2
