Thoughts and comments on this computer build. I have my heart set on the case, so I'm not going to change that. I also am not going to change the graphics card because I already own an RX 64, and I am just going to re-use it.
In other words, I'm flexible on everything but the case and the graphics card
In terms of budget, keep it under a $1000 (excluding the graphics card, don't factor that into the price). What am I going to use this computer for? Gaming and coding in college. Lots of google chrome tabs. I definitely want at least 16 GB of RAM and 500 GB of storage.
PCPartPicker Part List
CPU: AMD - Ryzen 7 2700X 3.7 GHz 8-Core Processor  ($279.99 @ Amazon)
CPU Cooler: Noctua - NH-L9a-AM4 33.84 CFM CPU Cooler  ($39.90 @ Amazon)
Motherboard: ASRock - B450 GAMING-ITX/AC Mini ITX AM4 Motherboard  ($109.99 @ Newegg)
Memory: G.Skill - Ripjaws V Series 16 GB (1 x 16 GB) DDR4-3200 Memory  ($85.98 @ Newegg)
Storage: Samsung - 970 Evo Plus 500 GB M.2-2280 Solid State Drive  ($125.50 @ Amazon)
Video Card: Sapphire - Radeon RX VEGA 64 8 GB Video Card
Case: Fractal Design - Node 202 HTPC Case  ($69.79 @ Amazon)
Power Supply: SeaSonic - FOCUS SGX 650 W 80+ Gold Certified Fully Modular SFX Power Supply  ($122.00 @ Amazon)
Total: $919.13
Generated by PCPartPicker 2019-05-17 21:04 EDT-0400
EDIT 1:
Probably going to switch to the Silverstone RVZ01 for the case instead of the Node 202.
Edit 2:
ALRIGHT. So this is the new build I came up with -- keeping in mind people's suggestions:
CPU: Intel - Core i7-8700 3.2 GHz 6-Core Processor  ($299.99 @ Newegg)
CPU Cooler: Noctua - NH-L9i 33.84 CFM CPU Cooler  ($39.95 @ Amazon)
Motherboard: ASRock - H370M-ITX/ac Mini ITX LGA1151 Motherboard  ($99.99 @ Amazon)
Memory: Corsair - Vengeance LPX 32 GB (2 x 16 GB) DDR4-3000 Memory  ($159.99 @ Corsair)
Case: Silverstone - RVZ01B Mini ITX Desktop Case  ($103.99 @ B&H)
Total: $951.41
Generated by PCPartPicker 2019-05-18 02:16 EDT-0400
https://linustechtips.com/topic/1064778-mini-itx-build/
Whatever you do, don't put an 8 core cpu in there unless you are willing to deal with thermal throttling and/or undervolting. Something like a r5-2600 or intel i5-9600 might do better. Try adding as many fans as possible to keep things cool. Everything else looks fine to me
print "Hello World!" ("Hello World!")
https://linustechtips.com/topic/1064778-mini-itx-build/#findComment-12575732
7 minutes ago, RobFRaschke said:
I'm just going to throw out that it's a hell of a lot of heat in that tiny of a case...
Oh jeez. New plan. Is there another mini-ITX case where I won't have to sacrifice an 8 core CPU? I'm willing to give up that case if I can keep a high-core CPU however I would still like the case to be relatively portable (and durable).
https://linustechtips.com/topic/1064778-mini-itx-build/#findComment-12575740
You are going to want to knock that down to a 6 core. Other than that, just undervolt your Vega 64 and overclock (very possible on Vega cards. AMD's voltages are insanely high from stock).
May I ask why you're buying 2 16GB Ram modules, rather than one 32GB kit?
Looks good other than those 2 things.
Brands I wholeheartedly reccomend (though do have flawed products): Apple, Razer, Corsair, Asus, Gigabyte, bequiet!, Noctua, Fractal, GSkill (RAM only)
Wall Of Fame (Informative people/People I like): @Glenwing @DrMacintosh @Schnoz @TempestCatto @LogicalDrm @Dan Castellaneta
Useful threads:
How To Make Your Own Cloud Storage
Guide to Display Cables/Adapters
PSU Tier List (Latest)-
Main PC: See spoiler tag
Laptop: 2020 iPad Pro 12.9" with Magic Keyboard
PCPartPicker Part List: https://pcpartpicker.com/list/gKh8zN
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core OEM/Tray Processor  (Purchased For $419.99)
Motherboard: Asus ROG Crosshair VIII Formula ATX AM4 Motherboard  (Purchased For $356.99)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3000 Memory  (Purchased For $130.00)
Storage: Kingston Predator 240 GB M.2-2280 NVME Solid State Drive  (Purchased For $40.00)
Storage: Crucial MX300 1.05 TB 2.5" Solid State Drive  (Purchased For $100.00)
Storage: Western Digital Red 8 TB 3.5" 5400RPM Internal Hard Drive  (Purchased For $180.00)
Video Card: Gigabyte GeForce RTX 2070 8 GB WINDFORCE Video Card  (Purchased For $370.00)
Case: Fractal Design Define R6 USB-C ATX Mid Tower Case  (Purchased For $100.00)
Power Supply: Corsair RMi 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For $120.00)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For $75.00)
Total: $1891.98
Generated by PCPartPicker 2020-04-02 19:59 EDT-0400
身のなわたしはる果てぞ  悲しわたしはかりけるわたしは
https://linustechtips.com/topic/1064778-mini-itx-build/#findComment-12575741
Is there any way I can change that case and not make the performance sacrifices? Good question about the 32 GB RAM. I just want to fill both slots on the motherboard and figured I would never need to upgrade to 64 GB.
https://linustechtips.com/topic/1064778-mini-itx-build/#findComment-12575744
I recommend you take a look at this spreadsheet (source: r/sffpc). The Louqe Ghost S1 is the one I'd recommend if you're able to shell out some extra money due to it's modular design. General rule of thumb for itx cases: the bigger the case, the cooler your components.
https://linustechtips.com/topic/1064778-mini-itx-build/#findComment-12575747
As @Airdragonzsaid.
Also my question was why did you set it up as to purchase 2 individual sticks, rather than purchasing one kit with the same amount of RAM. There is usually a unit price discount.
Useful threads:
Total: $1891.98
https://linustechtips.com/topic/1064778-mini-itx-build/#findComment-12575748
You rang?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1064778-mini-itx-build/#findComment-12575775
I was thinking the latest version of the Raven might be good, the RVZ03. Anyone have thoughts on the case?
Seems like there might be some QC issues on the case, so I might go for the RVZ01. The RVZ02 has a smaller volume, which probably means worse temps.
8 minutes ago, fasauceome said:
You rang?
According the excel sheet linked above, it would be pushing it to put an RX 64 in an SG13.
https://linustechtips.com/topic/1064778-mini-itx-build/#findComment-12575785
Use the 65W TDP 2700 instead of the 105W 2700X. See https://noctua.at/en/products/cpu-cooler-retail/nh-l9a-am4/cpucomp.
Buying separate sticks of memory runs the small chance that they will not be able to run in dual channel mode. For peace of mind get a 2x16GB kit.
You may want to consider an Intel build.
Memory: Corsair - Vengeance LPX 32 GB (2 x 16 GB) DDR4-3000 Memory  ($174.99 @ Amazon)
Storage: Samsung - 970 Evo Plus 500 GB M.2-2280 Solid State Drive  ($125.40 @ OutletPC)
Total: $932.11
Generated by PCPartPicker 2019-05-17 22:44 EDT-0400
https://linustechtips.com/topic/1064778-mini-itx-build/#findComment-12575845
43 minutes ago, Daniel Z. said:
Best I could do in that case.
https://pcpartpicker.com/list/rcqp7W
What if I changed the case to https://www.silverstonetek.com/raven/products/index.php?model=RVZ01&area=en . I really don't want to buy a 2060 cause I have a spare vega 64.
https://linustechtips.com/topic/1064778-mini-itx-build/#findComment-12575869
Total: $932.11
I might go with the the i7-8700. Good point about the memory. The kit you suggested is cheaper anyways, so I'll definitely go that route.
Motherboard: MSI - H310I PRO Mini ITX LGA1151 Motherboard  ($85.36 @ Newegg Business)
Total: $936.78
Generated by PCPartPicker 2019-05-18 01:04 EDT-0400
https://linustechtips.com/topic/1064778-mini-itx-build/#findComment-12575872
19 minutes ago, brob said:
H310 motherboards are intended for low-end builds. At the very least you should consider a B360 motherboard, but really an H370 strikes me as a better choice for an i7.
Sounds good, I swapped the board for the one you suggested in your earlier build.
https://linustechtips.com/topic/1064778-mini-itx-build/#findComment-12576123
AIGHT. Here's the final computer (middle of first picture). The graphics card is missing because that's in storage near my college, so currently I'm just using a filler card I had lying around. I used a 65mm noctua cooler instead of the 35mm one. Also, the RVZ01 is a special kind of hell to build in.
Far left is full tower. Far right is mid-tower. In between full tower and mid-tower is a can. Gives perspective on the size of the case.
https://linustechtips.com/topic/1064778-mini-itx-build/#findComment-12586152
