Do i need more RAM for larger Photoshop images? (iMac 27 Late 2012 entry lvl)
So im a photographer and im working with this 46 MP camera producing 41-53 mb files, my workflow consists on Photoshop and Lightroom, Firefox, iTunes + some other app at the same time, iMac used to do well with 16 mp sized images but these new 46mp files are just massive specially when converted to tiff and turning into 400mb - 3gb files on PS layers and stuff.
Computer go Slow as s*** while switching between apps. (Though i'm using a 1tb hdd 7200rpm which i know it's not ideal for PS cache or saving big files but thats another lack of performance i know i'm not gonna get fixed) .
So im thinking about a RAM upgrade but i don't know if this will turn my workflow at least a tad better, i know im working on a 7 Year old machine. Based on my research, Photoshop and Lightroom don't use so much GPU and the Processors on these Apps are used mainly to export-import, and i dont have any problem with these tasks (i ignore so much things about this, i'm sorry).
I'm currently using the standard 8 gb of RAM coming out of the box, in case Ram benefits my case, should i upgrade to 16 (adding 8 more) or go straight 32 with brand new units? Thanks for the advice.
iMac 27" Late 2012 (First slim iMac, entry level)
Intel Core i5 2.9Ghz
8Gb 1600 MHz DDR3 memory
Nvidia Geforce GTX 660M 512
1Tb 7200RPM Hard Drive
*laughs in windows* yeah another 8GB could help, don’t know how much though
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
Personally, I'd start with an SSD, using Time machine to backup and restore, or Minitool partition Wizard on another pc to clone your old drive to the new one. That drive is getting murdered by PS. Adding 8 more plus the SSD is my recommendation. Though I will warn you those iMacs are quite the trip to take apart.
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
I would change that 1TB hdd for an 1TB SSD, those are only 160€ these days, and for the ram...
Some photoshop files i have are struggling to fit into my 32GB of ram, thought that is when creating a 60mPix panorama from 10+ 20mPix images.
So go straight to 32gb, but 16gb would also be a big help for your use case.
The system being super slow is because of your hdd mostly, because of the page file etc being on it. SSD+16GB would be the best upgrade.
I only see your reply if you @ me.
This reply/comment was generated by AI.
16GB is fine for just Photoshop and if you work on just one image at a time. I run 32GB, but that is because I composite 50+ layers, and run Lightroom and pano stitching software at the same time in Windows 10.
You can check the Efficiency % in Photoshop and see how you are doing with 8GB. If you are consistently above 50%, then just go with 16GB.
4 minutes ago, Origami Cactus said:
.......The system being super slow is because of your hdd mostly, because of the page file etc being on it. SSD+16GB would be the best upgrade.
No, that is incorrect. Photoshop uses very little scratch disk as long as sufficient RAM is available.
Just don't laugh at me guys XD, as i'm just holding my ass for those incoming Ryzen 3000 and building a new Rig with Noctua Cooler and tons of RAM already bought, is just i need to deliver Photos and bussiness is doing well so...
The problem with checking the efficiency is that he see that he is low on RAM (less than 90% efficient,) but he won't know by how much.
This is incorrect. History states and cache are all held on disk.
Do you have four 8 GB modules of RAM plus an SSD cache? If so, take out 3 modules of RAM and see how well you do.
I didn't say that Photoshop doesn't use RAM. I said that it uses RAM and disk storage.
Try running the Puget Systems Photoshop benchmark:
https://www.pugetsystems.com/labs/articles/Puget-Systems-Adobe-Photoshop-CC-Benchmark-1132/
This eats about 60GB of disk usage during the benchmark and I don't come close to running out of RAM.
Quoted directly from Adobe:
Photoshop reads and writes image information to disk when your system doesn’t have enough RAM to contain all of it. The Efficiency indicator can help you determine whether getting a faster hard disk or solid-state disk would improve your performance. If the efficiency number is usually above 95%, spending money on a faster scratch disk has little benefit.
https://helpx.adobe.com/photoshop/kb/optimize-photoshop-cc-performance.html
Rather than taking this claim at face value, why don't you try running the benchmark and find out for yourself?
Or if you don't trust a 3rd party benchmark, just open a large file and perform a few dozen random actions (heal/clone, blurs, warps, transforms, resizes). Then, do Edit > Purge > All. Note your available disk space before and after, and you'll see that this changes. Photoshop writes to disk regardless of whether or not you have sufficient RAM.
Well, about this, i tweaked a little bit photoshop performance settings, assigned an External Scratch disk and i'm getting 100% efficiency right at the file openning with 4 layers (3 curves with masking and one transparent of healing brush work)
Your efficiency percentage will be at 100% until you start running out of RAM, so the indicator will only be meaningful after you perform a bunch of actions.
Try starting from scratch on an image with your normal workflow and see how you are doing after 15 minutes.
How much RAM are you allocating to Photoshop? Around 80-90%? If your main problem is the system being slow when switching programs, it may be beneficial to reduce how much you are allocating to Photoshop so that other programs have more available.
My PS Performance configuration is set as images show below, those are the tweaks i did, note that until this point i was working with default settings.
Well, I do trust Adobe since they wrote the software and wrote the article Optimize Photoshop CC Performance > Broad Steps to Boost Performance > Optimize your Hardware Setup.
Yes, this is true.
I do agree that an SSD would be a great thing to have, especially at today's prices. Boot up, opening Photoshop, opening images, and saving images would all be much, much faster. A 500GB Crucial MX500 or WD Blue, for example, would be SWEET!
Yes, for my next rig i already bought one Samsung 970 EVO Plus NVME M.2 for windows and PS, plus a WD Blue M.2 for scratch or caching.
David, that looks perfect. I was going to tell you to assign about 5-6 GB to Photoshop. You need to leave some for Windows and the other programs, however, I have heard of people assigning 100% to Photoshop without untoward effects.
By the way, Photoshop depends more on single core performance, not millions of threads. Adobe has also been optimizing their software for decades to work with Intel and Nvidia. Do wait for Ryzen 3000 to check it out, but do your homework and don't assume it's going to whoop up on Intel in Photoshop. Keep an eye on Puget who will likely test it soon after it's available.
My main goal when building my future system is longevity, im waiting for those Ryzen cus Intel and Nvidia Prices may drop (and im going Nvidia all day long no matter the cost) but also there's a rumored 12 core near-5ghz AMD processor, i was actually putting my eye on the i7 9700k (recomended by Puget for Photo work BTW). So you recommend me Intel over AMD for my main work right?
Today, I do, but once Ryzen 3000 comes out, we'll just have to see. Like you, I expect some pricing changes on both sides in our favor.
I work with files that are in the Gigabyte range with 16gb just fine.. I couldn't do a 50GB with 16GB as I've tried it for shits and giggles and took quite a few minutes trying to open it..
Ryzen 3800X + MEG ACE w/ Radeon VII + 3733 c14 Trident Z RGB in a Custom Loop powered by Seasonic Prime Ultra Titanium
PSU Tier List | Motherboard Tier List | My Build
