High guys I’m just needing a little help with choosing a case I’m building a dual pc system that’s going to be fully liquid cooled but my problem I’m having is the 2 mobo’s I have are the x99 godlike carbon which is extended ATX and an Rog strix B360 g micro ATX. Which I just can’t find a good case for them so if you guys can help it will be much appreciated  both systems will have a Gtx 1080 in them and at the bare minimum will have 2 240mm rads need storage shelving for at least 6 HDD’s an 2 SSD’s thanks
https://linustechtips.com/topic/1064658-need-help-on-a-case/
If you want 2 PCs in the same case, one of them is going to have to be itx
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
https://linustechtips.com/topic/1064658-need-help-on-a-case/#findComment-12574785
Just now, J2fourx said:
So basically there is no way of doing it with the mobos I have now?
Correct. There are, however several cases that offer multi pc setups, such as the phanteks evolv X
https://linustechtips.com/topic/1064658-need-help-on-a-case/#findComment-12574798
-Topic Moved to Cases and Power Supplies-
6 minutes ago, Grockle88 said:
Correct.
INCORRECT
@J2fourx Thermaltake makes the Core W200 which (while it's large) can hold two systems in the same case.
https://pcpartpicker.com/product/Qfs8TW/thermaltake-core-w200-atx-full-tower-case-ca-1f5-00f1wn-00
If you can find one, the Lian LI PC-666 can hold an E-ATX at the front and an mATX case in the back (which sounds like it would be PERFECT for you) but it was discontinued a few years ago so your best bet is the used market.
There's also the watercoolable Cougar Gemini X
https://www.amazon.com/Cougar-Gemini-Computers-Within-Single/dp/B07KTQP4LH
https://linustechtips.com/topic/1064658-need-help-on-a-case/#findComment-12574832
@TVwazhere I apologize, I had not heard of this being a thing
https://linustechtips.com/topic/1064658-need-help-on-a-case/#findComment-12574842
They are extremely rare. Cases like the Evolv X and Corsair 1000D have been able to ea silly implement a mini ITX system into their chassis, and some specially designed cases like the Phanteks Enthoo Mini XL can do simultaneous mITX and mATX. These are great for people who want let say a streaming system and a gaming system but want the relative size of only one tower.
As you might be able to guess they're a very niche corner of the market, so theres not alot of them out there in the wild, but if you know where to look, you can find almost anything ;)
https://linustechtips.com/topic/1064658-need-help-on-a-case/#findComment-12574857
thanks unfortunately being the niche corner sometimes is difficult especially when you want to have everything in your build lol
i was thinking about making a case if i couldn't find one but that requires alot of work around my busy work schedule i doubt i could make the case within 6-8 months which isnt ideal.
https://linustechtips.com/topic/1064658-need-help-on-a-case/#findComment-12576509
INCORRECT
holy crap that thing is huge
https://linustechtips.com/topic/1064658-need-help-on-a-case/#findComment-12576510
