I have the following specs:
CPU: Ryzen 5 2600
MOBO: MSI B450 A-PRO
RAM: G.SKILL RIPJAWS 8x2 DDR4 (3200MHz)
GPU: RX 580 8GB
PSU: M12 EVO 520
SSD: PATRIOT 240
The DRAM frequency is at 2133Mhz and i want to change it at 3000Mhz but i dont know how much the voltage should be then. It's at 1.224 (Auto).
https://linustechtips.com/topic/1062949-dram-frequency-and-voltage/
A-XMP, XMP or DOCP are all possible ways it's called, just enable that and it should raise your frequency. If it has 2 profiles, then one of the two will be 3200MHz and the other either 3000 or 2933.
Desktop benching:
5 hours ago, FTL_Error404 said:
I tried both XMP Profilers (one js 2933 and the other one 3200)..none of them is working, my ram speed is still 2133 when I'm looking at CPU-Z
well, that is strange, but maybe CPU-Z is showing incorrect info, and sometimes even the bios report 2133 after setting XMP profile while it is actually 2933 or 3200, to make sure about that, try AID64 extreme trial then check your RAM frequency, it should show the correct value, something like this down there
try it then report your result here.
