So I build myself a nice $600CAD computer a few weeks ago and I am having a few problems with it (see literally every other post I have) and now I have found a new problem. yay.
When I check tesk manager, I see that steam and discord are both running 32-bit. I am definately running windows 10 64-bit on a R3 2200G 64-bit cpu so how come both of these kind of important programs are running at 64-bit?
Update: RESOLVED
Edited by oakaxe
issue resolved
https://linustechtips.com/topic/1061948-64-bit-cpu-running-32-bit/
Some apps only have a 32 bit version. Steam and discord to name a couple.
Primary PC:
PSU tier list
How many watts do I need?
x86-64 based processors, which is basically 64-bit Intel/AMD processors for all intents and purposes, can run 32-bit applications as part of being backwards compatible. Windows has ways to run 32-bit apps through a compatibility layer called WoW64 (https://en.wikipedia.org/wiki/WoW64) using said processor feature.
40 minutes ago, TehPlayer14 said:
From what I know x64 system emulators 32-bit which implies it's not perfect especially with older games
39 minutes ago, Wufflez said:
Some apps don't need huge amounts of memory allocated to them. For that reason, there are sometimes both 32-bit and 64-bit applications. Sometimes there isn't a 64-bit version.
Oh ok thanks guys. Just wanted to know if there was just another problem with my PC. This sure puts me at ease
Many apps to this day are coded in 32 bit. Either because they were designed in the 32 bit era and simply updated rather than re-done for a new architecture, or because there is simply no reason to complicate things further by coding for 64 bit.
There is absolutely no issue with running 32 bits on a 64 bit OS. Try the other way around? Then yeah, that's an issue.
Brands I wholeheartedly reccomend (though do have flawed products): Apple, Razer, Corsair, Asus, Gigabyte, bequiet!, Noctua, Fractal, GSkill (RAM only)
Wall Of Fame (Informative people/People I like): @Glenwing @DrMacintosh @Schnoz @TempestCatto @LogicalDrm @Dan Castellaneta
Useful threads:
How To Make Your Own Cloud Storage
Guide to Display Cables/Adapters
PSU Tier List (Latest)-
Main PC: See spoiler tag
Laptop: 2020 iPad Pro 12.9" with Magic Keyboard
PCPartPicker Part List: https://pcpartpicker.com/list/gKh8zN
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core OEM/Tray Processor  (Purchased For $419.99)
Motherboard: Asus ROG Crosshair VIII Formula ATX AM4 Motherboard  (Purchased For $356.99)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3000 Memory  (Purchased For $130.00)
Storage: Kingston Predator 240 GB M.2-2280 NVME Solid State Drive  (Purchased For $40.00)
Storage: Crucial MX300 1.05 TB 2.5" Solid State Drive  (Purchased For $100.00)
Storage: Western Digital Red 8 TB 3.5" 5400RPM Internal Hard Drive  (Purchased For $180.00)
Video Card: Gigabyte GeForce RTX 2070 8 GB WINDFORCE Video Card  (Purchased For $370.00)
Case: Fractal Design Define R6 USB-C ATX Mid Tower Case  (Purchased For $100.00)
Power Supply: Corsair RMi 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For $120.00)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For $75.00)
Total: $1891.98
Generated by PCPartPicker 2020-04-02 19:59 EDT-0400
身のなわたしはる果てぞ  悲しわたしはかりけるわたしは
Ok thanks :D
