baseclock and fps
Just now, Mr Magic Man said:8700k 4.9ghz
2080ti
trident Z 3200 CL16 16GB
Aorus gaming 7RM850X
it seems so strange as I used to have a 1080ti and i have had better performance
double check your RAM frequency using CPU-Z, I don't know how you could possibly have better performance assuming you didn't change anything, your GPU is not even fully utilized, so it won't boost clocks because it doesn't need to, it's just chilling there waiting for the CPU, it's possible that the CPU itself is being the bottleneck, or the CPU is being bottlenecked by something else which would be the RAM, it's all a chain, RAM>CPU>GPU, and I have no idea which game you're testing, is it CSGO?
But again it really depends on the game, not all games are optimized well enough to better use your 8700K
