Will 5400rpm HDD be too slow for HDD specifically set for Video saving and editing?
Solved by SupaKomputa,
Yes, 5400rpm will be 30% slower than 7200rpm.
For video editing if you don't have many rams, the hdd will slow you down.
My suggestion is, use the 5400 as a storage, not a working drive.
Unload the files in your 7200rpm to the 5400, and put the working files in there.
SATA 2 is enough for older HDD less than 150MB/s drive.
Also this is 2019, have you thought about SSD?
