So I currently have a single D5 pump that’s powered by molex cable and then a 4 pin to the AIO header on my motherboard. Is it recommended to use the AIO header? I plan on getting a second one and there is only one AIO header typically so I was wondering since it’s PWM can I hook up to say my commander pro PWM headers. Although which is the preferred headers?
https://linustechtips.com/topic/1059270-pwm-d5-pumps/
Doesn't matter which header you use. So long as you can control the PWM you're fine.
If you're interested in a product please download and read the manual first.
Don't forget to tag or quote in your reply if you want me to know you've answered or have another question.
https://linustechtips.com/topic/1059270-pwm-d5-pumps/#findComment-12523194
Any PWM header will work fine.
If you put it on the motherboard AIO header it will probably run at 100% since those headers are made to run AIOs at full speed.
If you want speed control of the pump then you should use a different one.
https://linustechtips.com/topic/1059270-pwm-d5-pumps/#findComment-12523198
