Can't find a high enough ITX CPU cooler for Louqe Ghost
Solved by WoodenMarker,
19 hours ago, LlamaFamah said:Would a 120mm aio be a higher tdp? What would that tdp be?
It'd probably perform better.
The TDP spec isn't usually reliable since there's little to no regulation for how it's measured between different manufacturers. Look at benchmarks and in-depth reviews comparing coolers instead when possible.
As @Jurrunio mentioned, planning a bit later is probably better.
