1 hour ago, TipperTopTax said:
I would like advice on this build. This is my first build. https://pcpartpicker.com/user/TipperTopT4x/saved/vhYBrH
You want a ATX 3.0 psu for these RTX 40XX cards due to the adapter. Try this:
PCPartPicker Part List
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  ($339.99 @ Amazon)
CPU Cooler: *Thermalright Phantom Spirit 120 SE 66.17 CFM CPU Cooler  ($35.90 @ Amazon)
Motherboard: *MSI B650 GAMING PLUS WIFI ATX AM5 Motherboard  ($169.99 @ MSI)
Memory: *Silicon Power Value Gaming 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($94.97 @ Amazon)
Storage: *Silicon Power UD90 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($104.97 @ B&H)
Video Card: *Gigabyte WINDFORCE OC GeForce RTX 4070 SUPER 12 GB Video Card  ($599.99 @ B&H)
Case: *Montech AIR 903 BASE ATX Mid Tower Case  ($64.79 @ Newegg)
Power Supply: *SeaSonic FOCUS GX-750 ATX 3.0 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($89.99 @ Amazon)
Total: $1500.59
Generated by PCPartPicker 2024-06-13 00:59 EDT-0400
https://linustechtips.com/topic/1573429-advice/#findComment-16437612
I'm not an expert PC builder, nor do I know the use case of your machine, but I can assure you that 512gb is just not enough for ANYTHING, even on an entry level machine like mine, let alone an RTX 40 series build like yours.
1 hour ago, Why_Me said:
Just get a normal M.2 SSD instead of going with NVME. If you really need an NVME SSD, you gotta compromise somewhere else.
https://linustechtips.com/topic/1573429-advice/#findComment-16437631
Compromise? That's 2TB for $105.
https://linustechtips.com/topic/1573429-advice/#findComment-16437641
M.2 is the form-factor.
The motherboard (and CPU) ONLY supports NVMe type M.2 SSDs. OP doesn't have a choice to go M.2 SATA.
The cheapest "not shady" 2.5" 2TB SATA SSD listed on PCPartPicker is the TeamGroup QX, at $95
$105 for 2TB NVMe is actually a pretty good price...considering a mediocre Crucial BX500 2.5" SATA SSD is already $125.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1573429-advice/#findComment-16437657
I like the recommendations, but I don't need the extra memory. I don't play many games and don't need the extra storage.
https://linustechtips.com/topic/1573429-advice/#findComment-16437973
The cheapest 16GB (8GB X2) DDR5-6000 CL30 memory kit COSTS MORE than the 32GB (16 GB X 2) kit...
https://pcpartpicker.com/product/zWhv6h/kingston-fury-beast-rgb-16-gb-2-x-8-gb-ddr5-6000-cl30-memory-kf560c30bbak2-16
You can save ~$30 for going down to a 1TB NVMe SSD instead.
Then again, it's $30, you are not shaving off $50 or $100+
https://pcpartpicker.com/product/rqhv6h/western-digital-blue-sn580-1-tb-m2-2280-pcie-40-x4-nvme-solid-state-drive-wds100t3b0e
You can trim another $15 ~ $20 from the motherboard...gong for a lower-end board...
But you also lose the built-in WiFi / Bluetooth, or have to drop down to mATX rather than ATX.
https://pcpartpicker.com/product/jN3gXL/asrock-b650-pg-lightning-atx-am5-motherboard-b650-pg-lightning
https://pcpartpicker.com/product/nGKKHx/asus-prime-b650-plus-atx-am5-motherboard-prime-b650-plus
75% of your cost is the CPU + GPU + Motherboard
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
https://linustechtips.com/topic/1573429-advice/#findComment-16438401
The case has four fans, you don't really need any more.
Get a 1TB PCIe 4.0 NVMe drive. I have never known storage needs to stay static or shrink.
https://linustechtips.com/topic/1573429-advice/#findComment-16438456
Well since you don't give any info regarding your needs, can you do so now?
We have a form for this exact purpose, so we're not guessing.
Please fill out the form, located in the stickied post in the New Builds sub forum.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1573429-advice/#findComment-16438769
